[GRASS-user] Selecting EPSG from ogrinfo output; input from command line
Applying 'ogrinfo -al -so' to a *.gdb/ directory provides these results:
Layer name: CityUGA2017
Geometry: Multi Polygon
Feature Count: 534
Extent: (674051.583302, 86611.416792) - (2518331.287780, 1346099.208507)
Layer SRS WKT:
PROJCRS["NAD83(HARN) / Washington South (ftUS)",
     BASEGEOGCRS["NAD83(HARN)",
         DATUM["NAD83 (High Accuracy Reference Network)",
             ELLIPSOID["GRS 1980",6378137,298.257222101,
                 LENGTHUNIT["metre",1]]],
         PRIMEM["Greenwich",0,
             ANGLEUNIT["degree",0.0174532925199433]],
         ID["EPSG",4152]],
     CONVERSION["SPCS83 Washington South zone (US Survey feet)",
         METHOD["Lambert Conic Conformal (2SP)",
             ID["EPSG",9802]],
         PARAMETER["Latitude of false origin",45.3333333333333,
             ANGLEUNIT["degree",0.0174532925199433],
             ID["EPSG",8821]],
         PARAMETER["Longitude of false origin",-120.5,
             ID["EPSG",8822]],
         PARAMETER["Latitude of 1st standard parallel",47.3333333333333,
             ID["EPSG",8823]],
         PARAMETER["Latitude of 2nd standard parallel",45.8333333333333,
             ID["EPSG",8824]],
         PARAMETER["Easting at false origin",1640416.667,
             LENGTHUNIT["US survey foot",0.304800609601219],
             ID["EPSG",8826]],
         PARAMETER["Northing at false origin",0,
             ID["EPSG",8827]]],
     CS[Cartesian,2],
         AXIS["easting (X)",east,
             ORDER[1],
             LENGTHUNIT["US survey foot",0.304800609601219]],
         AXIS["northing (Y)",north,
             ORDER[2],
     USAGE[
         SCOPE["unknown"],
         AREA["USA - Washington - SPCS83 - S"],
         BBOX[45.54,-124.4,47.61,-116.91]],
     ID["EPSG",2927]]
Data axis to CRS axis mapping: 1,2
FID Column = OBJECTID
Geometry Column = Shape
CITY_NM: String (40.0)
UGA_NM: String (64.0)
UGA_NM2: String (64.0)
COUNTY_NM: String (15.0)
GMA: String (3.0)
FIPS_PLC: String (5.0)
INCORP: String (3.0)
ORIGIN: String (29.0)
DATEMOD: Real (0.0)
Shape_Length: Real (0.0)
Shape_Area: Real (0.0)
I've included all output while the projection codes are all at the top. My
questions are:
1.) Which EPSG code do I use to create a new location in which to import
this file? And should this be the first step?
2.) Or, could I use v.in.ogr directly on the command line to import it? When
I tried 'v.in.ogr in=/data/states/Washington/cities/CityUGA.gdb out=cities"
GRASS threw me an error.
TIA,
Rich
This is EPSG:2927 see: http://epsg.io/2927
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
Jeff,
So, it's the last one and marked 'ID'. That's good to know for other .gdb
data sources.
Thanks very much,
Rich
Jeff, et al.:
Please educate me what I've done incorrectly here.
Using the above EPSG (with /data/grassdata/ as the pwd) I entered:
grass79 -c EPSG:2927 /data/grassdata/Washington/cities/
which is the location I want to create for these data.
Because EPSG:2927 was the ID value when I ran 'ogrinfo -al -so' on
/data/states/Washington/cities/CityUGA.gdb I assumed that the created
location was using the proper CRS. That's apparently not the case:
v.in.ogr in=/data/states/Washington/cities/CityUGA.gdb out=cities ERROR: Projection of dataset does not appear to match current location.
        Location PROJ_UNITS is:
        unit: meter
        units: meters
        meters: 1
        Dataset PROJ_UNITS is:
        unit: U.S. Surveyor's Foot
        units: U.S. Surveyor's Feet
        meters: 0.3048006096012192
        In case of no significant differences in the projection definitions,
        use the -o flag to ignore them and use current location definition.
        Consider generating a new location from the input dataset using the
        'location' parameter.
Same results when out=/data/grassdata/Washington/cities/ and when I cd to
that directory when I run v.in.ogr.
What am I missing?
Stay well,
Rich
That's the ultimate destination; the correct new location is
/data/grassdata/wa_cities. This resolves the issue.
Rich
