[GRASS-user] self compile grass- msys
Hi Helmut,
Thank you. Msys worked. But when I compiled it seams there are mistakes
showing in the package.log in the below:
Fri Sep 17 14:02:05 2010: STARTING configure
checking host system type... i686-pc-mingw32
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /c/mingw/bin/pwd
checking for source directory... /osgeo4w/usr/src/grass64
checking for build directory... /osgeo4w/usr/src/grass64
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)...
MINGW32_NT-5.2-1.0.11(0.46/3/2)
checking for dlopen in -ldl... no
there seems to be nothing obvious wrong, answers of checks can be "yes" and "no".
you can find the relevant things - if compiling fails - in /osgeo4w/usr/src/grass64/error.log.
- where did you install the osgeo4w-stack (i.e. c:\osgeo4w\ or in an another destination)
- please post the content of error.log
Helmut
___________________________________________________________
GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
