[GRASS-user] Sentinel2- flooding
I’ve obtained an image from sentinel2 where it shows flooding. Just wondering are there tools in Grass to classify an image in order to pull out these “flooded” pixels?
Thanks
Le gach dea ghui,
Shane Carey
GIS and Data Solutions Consultant
I Think there isn’t any tool pre-configured. You need to find an index to calculate “flooded” cells and then you can simply use r.mapcalc
R
Il giorno ven 7 dic 2018 alle ore 14:45 Shane Carey <careyshan@gmail.com> ha scritto:
Thanks
Le gach dea ghui,
Shane Carey
grass-user mailing list
grass-user@lists.osgeo.org
Ok, thanks.
Le gach dea ghui,
Shane Carey
Hi Shane,
Following up on robertos answer:
You could try the Normalized Difference Water Index (NDWI) which is computed for S-2 as:
ndwi = (B08-B11)/(B08+B11)
or alternatively
ndwi = (B03 - B08) / (B03 + B08)
See e.g.: https://github.com/sentinel-hub/custom-scripts/blob/master/sentinel-2/ndwi/script.js
You could also take a look at Sentinel-1 for flooding / water bodies. However, Sentinel-1 would have to be pre-processed in SNAP/gpt.
Stefan
Ok, thanks.
Le gach dea ghui,
Shane Carey
On Fri, Dec 7, 2018 at 2:45 PM Roberto Marzocchi <roberto.marzocchi@gmail.com> wrote:
R
Thanks
Le gach dea ghui,
Shane Carey
Great thanks
Le gach dea ghui,
Shane Carey
On Fri, Dec 7, 2018 at 8:14 PM Stefan Blumentrath
<Stefan.Blumentrath@nina.no> wrote:
Hi Shane,
or alternatively
... or just adapt the bands here:
https://grass.osgeo.org/grass74/manuals/i.vi.html#calculation-of-ndvi
Yes, Sentinel-1 is probably more relevant when it comes to
identification of flooded areas.
Great - thanks all. I’ll let you know how I get on.
Thanks
Le gach dea ghui,
Shane Carey
