[GRASS-user] Sentinel2 para procesar imágenes de Sentinel-2 MSI L1C a L2A
Hello, it’s a pleasure to greet you, hoping you are well. Has anyone processed sentinel 2 images to convert from level to L1C to L2A? Thank you very much! Eddison
Hei Eddision,
Currently you will have to use a 3rd party solution for that (e.g. sen2cor).
Please note that ESA is conducting a “Atmospheric Correction Inter-comparison Exercise” (ACIX) where the different available algorithms are benchmarked against each other: https://earth.esa.int/web/sppa/meetings-workshops/acix
L2A products will become directly available from ESA in 2017.
Stefan
On Thu, Nov 17, 2016 at 3:30 AM, Eddison Araya <eddisonjose@gmail.com> wrote:
Hello, it's a pleasure to greet you, hoping you are well. Has anyone
Yes, we do that frequently (using sen2cor which not always works).
Best,
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Hola Stefan y Markus, muchas gracias por su respuesta
Saludos cordiales
Eddison
2016-11-17 1:51 GMT-06:00 Blumentrath, Stefan <Stefan.Blumentrath@nina.no>:
Hei Eddision,
Stefan
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Eddison Araya
Sent: 17. november 2016 03:30
To: GRASS user list <grass-user@lists.osgeo.org>
Subject: [GRASS-user] Sentinel2 para procesar imágenes de Sentinel-2 MSI L1C a L2A
