Milton Cezar Ribeiro wrote:
I have a set of 10,000 distance maps. On this map I have
negative (-300 to 0) and posivie (0 to +300) values.
I would like to attrib a color table to those maps
from yellow-cyan-dark green when the negative values
goes from 0 to -300, and from yellow-orange-red
when values goes from 0 to +300
I'm not sure if you have raster maps or vector, but I think the answer will
be similar either way. With raster, you can use r.colors to set the color
table of the map (with vector, I think v.colors works in a similar way). In
r.colors, you can specify a rules file for the colors. The format of the
rules file is quite flexible, you can set the values for particular colors
either as absolute values (e.g. -300 or +300) or as percentages defined
based on the whole range of values (e.g. 0% or 100%). Colors can also be
specified using either common color names ("red") or rgb triplets (255 0 0).
As far as I can tell, you can mix and match formats at will. r.colors
manual will give more info.
I was doing something very similar recently (having opposing scales for
negative and positive values, with white representing 0). The code I used
was
r.colors map=$rast
rules=/usr/color_tables/TreeCoverChange_RedWhiteGreen.file
With the rules file being a text file containing the following:
0% 255 0 0
-0.5 255 240 180
0 white
0.5 180 230 130
100% 0 70 0
Those aren't the colors you want (mine was red for negatives, green for
positives, but that's the idea). You would do something like the following
0% (whatever the RGB values for dark green are)
0 (whatever the RGB values for yellow are)
100% red
Also, I had a problem with color tables set for negative values when I was
displaying data through the plugin in QGIS. I never figured that out except
by manually setting the colors in QGIS itself. But as long as I was
displaying in GRASS directly (using the PNG driver and d.rast), r.colors
worked fine.
HTH
Tim
View this message in context: http://n2.nabble.com/set-color-for-negative-and-positive-values-tp3591519p3591660.html
