[GRASS-user] Set default cell type to FCELL?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
- -----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I have huge values in my raster cells and I am manually always setting
thrm to FCELL. Is there a possibility to instruct GRASS to use FCELL
(or DCELL) as a default instead of CELL?
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
- -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk8LP5AACgkQoYgNqgF2egqIMwCfeWPRNyLlu9ZamOmLcECGoisV
81cAn0TBNu2YW7ugZ2o5eq/9XW6lvyV9
=eGtL
- -----END PGP SIGNATURE-----
iEYEARECAAYFAk8L9QAACgkQoYgNqgF2egqP4gCfRupO4ruYVzofwxiCDZY0r0at
5QkAniLru1bBiWMgfPJiWFfuwIfJ2jI5
=8sW9
not sure to have understood what you want to do but maybe using r.mapcalc functions:
- double(x) --> convert x to double-precision floating point
- float(x) --> convert x to single-precision floating point
Maxi
Hash: SHA1
Hash: SHA1
Hi
Thanks
Rainer
South Africa
Skype: RMkrug
=eGtL
=8sW9
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
Hash: SHA1
On 10/01/12 12:50, Massimiliano Cannata wrote:
Hi, not sure to have understood what you want to do but maybe
using r.mapcalc functions: - double(x) --> convert x to
double-precision floating point - float(x) --> convert x
Sorry for not being more clear.
What you suggest is exactly what I am doing - but it is very error
prone, as I have to put this into numerous calculations (this is part
of a simulation model).
What I would like to do is tho change the default type from CELL to
FCELL - i.e. whenever a new raster is created, it will *always* and
*automatically* be saved in a FCELL raster, even if it only contains
integer values, and not in a CELL raster.
Rainer
Maxi
On 01/10/2012 09:21 AM, Rainer M Krug wrote: -----BEGIN PGP SIGNED
MESSAGE----- Hash: SHA1
Hi
setting thrm to FCELL. Is there a possibility to instruct GRASS to
use FCELL (or DCELL) as a default instead of CELL?
Thanks
Rainer
- -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
(Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44 Cell: +33 - (0)6 85 62 59
98 Fax : +33 - (0)9 58 10 27 44
Skype: RMkrug -----BEGIN PGP SIGNATURE----- Version: GnuPG
v1.4.11 (GNU/Linux) Comment: Using GnuPG with Mozilla -
81cAn0TBNu2YW7ugZ2o5eq/9XW6lvyV9 =eGtL -----END PGP SIGNATURE-----
_______________________________________________ grass-user
mailing list grass-user@lists.osgeo.org
South Africa
Skype: RMkrug
iEYEARECAAYFAk8MKiUACgkQoYgNqgF2egqmOQCfR0VP+5VYGRK0r6ePFxIZ+Oa1
snQAnRLfyjq9JJFwZzAhDZuEoGA7x1s6
=vCXE
When you include in any one of your multiplication a number with at least one decimal your result should be a floating raster. Perhaps not as easy as what you are asking for, but it shouldn’t be too error prone, should it?
Paulo
Hash: SHA1
using r.mapcalc functions: - double(x) → convert x to
double-precision floating point - float(x) → convert x
FCELL - i.e. whenever a new raster is created, it will always and
automatically be saved in a FCELL raster, even if it only contains
Rainer
Maxi
Hi
Thanks
Rainer
  • – Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
South Africa
South Africa
Skype: RMkrug
=vCXE
Hash: SHA1
Perhaps not
so
oldmap * 1
results in a raster of the same type as oldmap,
where
oldmap * 1.0
would result in a FCELL?
as easy as what you are asking for, but it shouldn't be too error
prone, should it?
In principal not - but I have to check the whole simulation.
Rainer
Paulo
part of a simulation model).
to FCELL - i.e. whenever a new raster is created, it will *always*
and *automatically* be saved in a FCELL raster, even if it only
contains integer values, and not in a CELL raster.
Rainer
Maxi
SIGNED MESSAGE----- Hash: SHA1
Hi
to use FCELL (or DCELL) as a default instead of CELL?
Thanks
Rainer
University South Africa
59 98 Fax : +33 - (0)9 58 10 27 44
email: Rainer@krugs.de <mailto:Rainer@krugs.de>
Skype: RMkrug
_______________________________________________ grass-user mailing
<mailto:grass-user@lists.osgeo.org>
South Africa
Skype: RMkrug
iEYEARECAAYFAk8MLcIACgkQoYgNqgF2egoSMQCePKxF92PrrqiAwqo2OLmlthyf
NkgAnjfdAf6dx1lz02Rnyu4g5gkPUZi3
=HmpG
Yes, also check the manual for r.mapcalc (e.g. http://grass.fbk.eu/gdp/html_grass64/r.mapcalc.html), it is described there somewhere I think
Hash: SHA1
Perhaps not
so
oldmap * 1
where
oldmap * 1.0
prone, should it?
Rainer
Paulo
to FCELL - i.e. whenever a new raster is created, it will always
and automatically be saved in a FCELL raster, even if it only
Rainer
Maxi
Hi
Thanks
Rainer
email: Rainer@krugs.de mailto:[Rainer@krugs.de](mailto:Rainer@krugs.de)
Skype: RMkrug
mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
South Africa
Skype: RMkrug
=HmpG
This isn't possible. If a module generates a CELL map, it's invariably
because it's performing the calculations using integers. Converting
the final result to floating-point wouldn't help; if the integer
calculations overflow, converting the result to floating-point won't
"undo" the overflow.
Some modules will generate either integer or floating-point output
depending upon the type of the inputs.
so
oldmap * 1
Arithmetic operations on mixed types promote to the lesser type to the
greater type, where CELL < FCELL < DCELL.
where
oldmap * 1.0
Actually, it will result in DCELL. r.mapcalc follows C syntax:
floating-point literals are double precision unless suffixed with an
"f", so "oldmap * 1.0f" will result in FCELL (unless oldmap is DCELL).
But float(oldmap) or double(oldmap) do the same thing but avoid the
gratuitous multiply operation.
Also:
1. If you are having issues with overflow, you need to promote values
before calculations, e.g. "float(x) * y". Using "float(x * y)" will
result in x*y overflowing, then the overflowed value will be
converted.
2. Single precision (FCELL) only has a 24-bit mantissa, so integers
greater than 2^24 (16777216) cannot always be represented exactly.
Double precision (DCELL) has a 53-bit mantissa.
Hash: SHA1
*always* and *automatically* be saved in a FCELL raster, even if
it only contains integer values, and not in a CELL raster.
Pitty - but makes sense.
If a module generates a CELL map, it's invariably because it's
performing the calculations using integers. Converting the final
won't "undo" the overflow.
Good point - so I have to change my approach.
Yes - I am referring mainly to r.mapcalc with the overflow - so I can
do the conversion in the formula.
so
oldmap * 1
the greater type, where CELL < FCELL < DCELL.
I assume the "to the lesser type" should be deleted? So they promote
to the higher type?
where
oldmap * 1.0
an "f", so "oldmap * 1.0f" will result in FCELL (unless oldmap is
DCELL).
OK.
Agreed - and I am using them - the * 1 was just a (not very good) example.
Also:
values before calculations, e.g. "float(x) * y". Using "float(x *
y)" will result in x*y overflowing, then the overflowed value will
be converted.
Very good point - have to go through my code again.
So I will go to DCELL and double().
things are much clearer now.
Rainer
South Africa
Skype: RMkrug
iEYEARECAAYFAk8NTD4ACgkQoYgNqgF2egpwQACfakWPvtlsaKBMBSbn10uNMLAR
PssAn0xf5gE+TSOujix1N2qs0Qw1aqoT
=4tuq
to the higher type?
The first "to" should be deleted, i.e. "promote the lesser type to the
greater type". IOW:
          | CELL FCELL DCELL
     CELL | CELL FCELL DCELL
    FCELL | FCELL FCELL DCELL
    DCELL | DCELL DCELL DCELL
Hash: SHA1
to the greater type, where CELL < FCELL < DCELL.
promote to the higher type?
the greater type". IOW:
| CELL FCELL DCELL ------+------------------ CELL | CELL FCELL
DCELL FCELL | FCELL FCELL DCELL DCELL | DCELL DCELL DCELL
Thanks for the clarification - One could add this possibly to the FAQ
or in the general description of GRASS?
Rainer
South Africa
Skype: RMkrug
iEYEARECAAYFAk8OoggACgkQoYgNqgF2egrONgCfatVhb3QapDwI8LLyaxX4R/gN
Pq8An2uEYJIdVM+8yp2g+jIEA3Y1rWXF
=Usvj
Sure (everybody can after registration):
http://grass.osgeo.org/wiki/GRASS_raster_semantics
