Hello all,
I have a set of geotiffs that have inf (infinity) values that I would like to set to nodata. How can I do that in GRASS or gdal?
Thanks!
Bob
Robert Moskovitz
California Geological Survey
Seismic Hazards Zonation Program
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
On Wed, Mar 19, 2014 at 8:18 PM, Moskovitz, Bob@DOC
<Bob.Moskovitz@conservation.ca.gov> wrote:
Hello all,
what does
gdalinfo -mm yourrastermap.tif
report as Min/Max?
Thanks for looking into this.
Here it is:
R:\SpecialProjects\tsunami work>gdalinfo --version
GDAL 1.10.1, released 2013/08/26
R:\SpecialProjects\tsunami work\>gdalinfo -mm NETCDF:pola_cascadiad_sift2.nc:max_speed
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Driver: netCDF/Network Common Data Format
Files: pola_cascadiad_sift2.nc
Size is 1810, 1100
Coordinate System is `'
Origin = (-118.302500000118700,33.779999999966194)
Pixel Size = (0.000092592592580,-0.000092592592587)
Metadata:
lat#long_name=latituded
lat#units=degrees_north
lon#long_name=longitude
lon#units=degrees_east
max_speed#long_name=Maximum Current Speed
max_speed#missing_value=-1e+034
max_speed#units=centimeters/second
Corner Coordinates:
Upper Left (-118.3025000, 33.7800000)
Lower Left (-118.3025000, 33.6781481)
Upper Right (-118.1349074, 33.7800000)
Lower Right (-118.1349074, 33.6781481)
Center (-118.2187037, 33.7290741)
Band 1 Block=1810x1 Type=Float64, ColorInterp=Undefined
Computed Min/Max=0.000,1.#IO
NoData Value=-9.9999999999999995e+033
Metadata:
NETCDF_VARNAME=max_speed
-----Original Message-----
From: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] On Behalf Of Markus Neteler
Sent: Sunday, March 30, 2014 2:39 PM
To: Moskovitz, Bob@DOC
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Set rasters with inf values to nodata
On Wed, Mar 19, 2014 at 8:18 PM, Moskovitz, Bob@DOC <Bob.Moskovitz@conservation.ca.gov> wrote:
Hello all,
what does
report as Min/Max?
On Tue, Apr 1, 2014 at 6:43 PM, Moskovitz, Bob@DOC
Here it is:
Honestly, I have never seen such Max value.
Maybe a GDAL or dataset issue?
Metadata:
This is the first time I've seen such Max values too. But I have been able to solve my problem by converting these files to Arc/info ASCII Grids and replace all "1.#INF" to my nodata value. I'll see if anyone on the GDAL ML can help me.
-Bob
Sent: Tuesday, April 01, 2014 12:39 PM
On Tue, Apr 1, 2014 at 6:43 PM, Moskovitz, Bob@DOC <Bob.Moskovitz@conservation.ca.gov> wrote:
Here it is:
R:\SpecialProjects\tsunami work>gdalinfo --version GDAL 1.10.1,
released 2013/08/26 R:\SpecialProjects\tsunami work\>gdalinfo -mm
Metadata:
