There is a shell command for set "computational region from display"?
Alfredo
Alfredo
2009/12/3 Alfredo Alessandrini <alfreale74@gmail.com>:
I guess you are referring to wxGUI. This options is available only
from Map Display Window.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Alfredo,
Are you referring to g.region? Use it specifying the map name; e.g.:
g.region vect=streams
or
g.region rast=elevation
HTH,
Rich
yes
from Map Display Window.Martin
ok, thanks
Alfredo
