Hi folks,
I’m looking for a way to set the computational region to that of the display window from within a script. I couldn’t find any d.* or g.* commands that did this.
What I am trying to do is pan around the wx monitor to different portions of my vector coastline, and then from the command line run a script that uses the current display area as its computational region and updates the attribute table of the features displayed in the region from null to some other value.
Any ideas on whether this is possible?
~ Eric.
* Eric Patton <thepattonian@gmail.com> [2018-02-13 03:02:59 -0800]:
Hi folks,
other value.
Maybe d.info -g
Nikos
On Tue, Feb 13, 2018 at 6:02 AM, Eric Patton <thepattonian@gmail.com> wrote:
Hi folks,
did this.
other value.
Not currently, you would have to hack the GUI now to for example write
somewhere a file every time you change zoom and then create a script
that reads in this file and sets the region.
Anna
~ Eric.
grass-user mailing list
grass-user@lists.osgeo.org
Ok, thanks Anna, that is what I thought.
~ Eric.
On 14 Feb 2018, at 9:25 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Tue, Feb 13, 2018 at 6:02 AM, Eric Patton wrote:
Hi folks,
did this.
other value.
Anna
~ Eric.
