[GRASS-user] Setting layer transparency from a script
Hello,
I'm using a Python script to generate maps for publication by setting
GRASS_RENDER_FILE and running the different d.* commands. Is it
possible to add opacity to some of the layers?
Laurent
Laurent C.:
Hello,
Dear Laurent,
not a direct answer, but you might want to read
<https://lists.osgeo.org/pipermail/grass-user/2016-March/073831.html&gt;
Also, the r.out.png tool has a "-t Make NULL cells transparent" flag.
Kind regards and thank you for your excellent work I've seen elsewhere.
Nikos
Hi Nikos,
What I would like is the possibility to set a percentage of opacity. But if I understand well, it is what is doing pnmcomp.
Thanks for your appreciation.
Laurent
On 11 Mar 2017 03:35, “Nikos Alexandris” <nik@nikosalexandris.net> wrote:
Laurent C.:
Hello,
I’m using a Python script to generate maps for publication by setting
Dear Laurent,
<https://lists.osgeo.org/pipermail/grass-user/2016-March/073831.html>
Also, the r.out.png tool has a “-t Make NULL cells transparent” flag.
Kind regards and thank you for your excellent work I’ve seen elsewhere.
Nikos
