[GRASS-user] setting no data color
I am trying to set no data, which represents ocean to blue. I see r.colors has a option to set nv to a color. I tried this and the oceans are still white. Any suggestions?
Jim
James (Jim) B. White
tel: (919)-380-9615
homepage: http://jimserver.net/
Jim
Jim,
.if you want to convert some of your values to NULLs then look at r.mull
.about the "nv" could you provide in detail what and how you set it? how
does your "color_settings" file look like?
> Jim
Jim,
Sorry,
that would be r.null
grass-user mailing list
grass-user@lists.osgeo.org
Here is the color file:
0 0 0 0
1 127 96 40
2 76 153 51
3 0 99 0
4 176 48 96
5 204 165 127
6 244 244 219
7 127 127 127
8 210 44 47
9 158 248 255
nv 191 233 255
end
If I can't get it to make nulls the color I want, I can change the nulls to zeros, but prefer to keep them null.
Jim
Jim
Jim,
Sorry,
tel: (919)-380-9615
Jim:
are you sure they are really NULL? check with d.what.rast? r.univar?
0 0 0 0
1 127 96 40
2 76 153 51
3 0 99 0
4 176 48 96
5 204 165 127
6 244 244 219
7 127 127 127
8 210 44 47
9 158 248 255
nv 191 233 255
end
looks ok. It should work; was working for me yesterday.
you shouldn't have to.
have a look in the $MAPSET/colr/$MAPNAME file too if you like.
Hamish
0 0 0 0
1 127 96 40
2 76 153 51
3 0 99 0
4 176 48 96
5 204 165 127
6 244 244 219
7 127 127 127
8 210 44 47
9 158 248 255
nv 191 233 255
end
In what context are they showing up as white?
Is it possible that they are being treated as transparent, over a
white background? E.g. "d.rast -o ..." treats nulls as transparent, so
the null colour doesn't have any effect. If you're using gis.m, raster
layers have the equivalent option, "overlay maps from other layers
(transparent null value cells)" enabled by default. OTOH, the option
is disabled by default in the wxPython GUI.
