[GRASS-user] setting output nodata values in grass
Hello all,
I’ve been processing quite a bit of terrain data in GRASS and am having an issue with output nodata values… Is there anyway to set the output nodata value when exporting a raster?
I use r.in.xyz to load gridded data, and then export it to GTiff using r.out.gdal. The output file ends up with a float for null areas, something like “NoData Value=-9.99999993381581e+36”. I’d like to set it too something simple like “-9999”. I can use “r.null map=blah null=-9999”, but then the metadata “NoData” flag doesn’t get set.
Is there a way to specify a specific nodata value, either for internal storage, or as a metaopt for r.out.gdal? I’m trying to get the import / export pipeline down to the least amount of steps possible.
Jamie
