[GRASS-user] Several questions about vector maps
Good night.
As newbie I’m creating a map of the Falkland Islands using the NASA’s SWBD shapefiles with GRASS 6.3RC6. After importing the ten tiles into GRASS in Lat/Lon, I merge them two by two using ‘v.overlay’ in order to have only one vector map. Isn’t there a better way to merge several pieces of map in one big in one operation ? Should I use ‘v.patch’ ? When I try to use this last I’ve got an error message box ‘couldn’t execute “v.patch”:invalid argument’. When I display this merged map, the sea areas are well displayed but I loose most of the lakes (the ones which weren’t filled with any color in the separate tiles.
When I create a new project in UTM and re-project my map with ‘v.proj’, the module tells me that there are many (200) incorrect boundaries, as well as centroids outside area and areas without centroids, and when I display the map, several sea areas are white, showing me clearly that something didn’t run fine. Can somebody tell me what is wrong ? Could it have something to do with the categories as I read in some threads ?
Thanks for your answers.
Eric
Eric,
I would do it with ogr2ogr. Find attached a small shell script doing that job.
cheers
On Tue, Apr 22, 2008 at 2:59 AM, Eric Gaba <eegaba@terra.com.br> wrote:
Good night.
As newbie I'm creating a map of the Falkland Islands using the NASA's SWBD
Lat/Lon, I merge them two by two using 'v.overlay' in order to have only one
vector map. Isn't there a better way to merge several pieces of map in one
big in one operation ? Should I use 'v.patch' ? When I try to use this last
I've got an error message box 'couldn't execute "v.patch":invalid argument'.
most of the lakes (the ones which weren't filled with any color in the
separate tiles.
When I create a new project in UTM and re-project my map with 'v.proj', the
map, several sea areas are white, showing me clearly that something didn't
Eric
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
(attachments)
ogr_shape_merge.sh (724 Bytes)
