[GRASS-user] sh: 1: v.net.components: not found
Dear GRASS user list,
While accessing GRASS via R i ran over the problem of missing a certain GRASS function: v.net.components
System:
Distributor ID: Ubuntu
Description: Ubuntu 12.04.3 LTS
Release: 12.04
Codename: precise
grass 6.4.1-1ubuntu2
Here is what i did in R (partly):
Created a stream network shape file via execGRASS( "v.net", ...)
and now I wanted to distinguish local stream networks:
execGRASS("v.net.components", flags="overwrite", parameters=list(input="Stream_known_Network",
+ output="Stream_known_connectivity", method="weak"))
Fehler in parseGRASS(cmd, legacyExec = legacyExec) : The command
    v.net.components --interface-description
could not be run (127), and produced the error message:
Then I looked wether v.net.components is installed,
dpkg -L grass|gedit
/usr/lib/grass64/bin/v.neighbors
/usr/lib/grass64/bin/v.net
/usr/lib/grass64/bin/v.net.alloc
/usr/lib/grass64/bin/v.net.iso
/usr/lib/grass64/bin/v.net.path
/usr/lib/grass64/bin/v.net.salesman
/usr/lib/grass64/bin/v.net.steiner
/usr/lib/grass64/bin/v.net.visibility
/usr/lib/grass64/bin/v.normal
And it seems like, it is not.
Is my version generally missing the function?
Some help would be very much appreciated,
Thanks very Much,
Gunnar
Gunnar Oehmichen
Quantitative Landscape Ecology
Institute for Environmental Sciences
University Koblenz-Landau
Fortstrasse 7
76829 Landau
Germany
http://www.uni-koblenz-landau.de/landau/fb7/umweltwissenschaften/landscape-ecology/Staff/gunnaroehmichen
Dear Gunnar,
On Thu, Oct 24, 2013 at 4:02 PM, Gunnar Oehmichen
You would need to update to at least the next dot release: 6.4.2 (bettet 6.4.3):
http://trac.osgeo.org/grass/wiki/Release/6.4.2-News#Newmodules
New modules
i.topo.corr - Computes topographic correction of reflectance in
satellite imagery
m.nviz.image - Creates a 3D rendering of GIS data (renamed from nviz_cmd)
v.net.allpairs - Computes the shortest path between all pairs of nodes
in the network
v.net.bridge - Computes bridges and articulation points in the network
v.net.centrality - Computes degree, centrality, betweeness, closeness
and eigenvector centrality measures in the network
v.net.components - Computes strongly and weakly connected components
in the network
v.net.connectivity - Computes vertex connectivity between two sets of
nodes in the network
v.net.distance - Computes shortest distance via the network between
the given sets of features
v.net.flow - Computes the maximum flow between two sets of nodes in the network
v.net.spanningtree - Computes minimum spanning tree for the network
v.net.timetable - Finds shortest path using timetables
It has been added to a newer release of GRASS 6 than you have
currently installed.
For ubuntu packages, see
http://grass.osgeo.org/download/software/linux/
Hope this helps,
Hey Markus,
after searching a bit, it seems like no stable Version of GRASS >= 6.4.2
is available for 12.04. . I hope I have missed a repository. Any hints on that?
Gunnar
Am 24.10.2013 16:17, schrieb Markus Neteler:
Dear Gunnar,
could not be run (127), and produced the error message: sh: 1:
(bettet 6.4.3):
http://trac.osgeo.org/grass/wiki/Release/6.4.2-News#Newmodules "
New modules
satellite imagery m.nviz.image - Creates a 3D rendering of GIS data
(renamed from nviz_cmd) v.net.allpairs - Computes the shortest path
between all pairs of nodes in the network v.net.bridge - Computes
bridges and articulation points in the network v.net.centrality -
Computes degree, centrality, betweeness, closeness and eigenvector
centrality measures in the network v.net.components - Computes
strongly and weakly connected components in the network
of nodes in the network v.net.distance - Computes shortest distance
via the network between the given sets of features v.net.flow -
v.net.timetable - Finds shortest path using timetables "
Hope this helps, Markus
Gunnar Oehmichen
Fortstrasse 7
76829 Landau
Germany
On 25/10/13 12:46, Gunnar Oehmichen wrote:
Hey Markus,
on that?
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
Moritz
Gunnar
Dear Gunnar,
(bettet 6.4.3):
New modules
