Hello,
I have 5 shape files part of knoxville metro area.
I am trying to bring them into grass as one map layer.
Should be able to do
v.in.ogr --overwrite dsn=/home/matthew/paper2/tenn/tenn_shp_files output=knoxville_bg2 layer=new_2_tgr47093grp00,new_2_tgr47001grp00,new_2_tgr47009grp00,new_2_tgr47105grp00,new_2_tgr47173grp00
but will only bring in the first listed shape file (which every one that happens to be) correctly. The others just show as lines with no centriods and will not show in qgis.
Is this a bug.
I really just want to merge the files so I can bring then in one at a time. But what do I do next.
Matthew
output
GRASS default for nad83 is
towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import…
WARNING: The vector ‘knoxville_bg2’ already exists and will be overwritten.
Layer: new_2_tgr47093grp00
Importing map 234 features…
Layer: new_2_tgr47001grp00
Importing map 64 features…
Layer: new_2_tgr47009grp00
Importing map 79 features…
Layer: new_2_tgr47105grp00
Importing map 30 features…
Layer: new_2_tgr47173grp00
Importing map 15 features…
Building topology …
423 primitives registered
Building areas: 100%
407 areas built
406 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 414
Number of primitives: 423
Number of points : 0
Number of lines : 0
Number of boundaries: 423
Number of centroids : 0
Number of areas : 407
Number of isles : 406
Number of incorrect boundaries : 17
Number of areas without centroid : 407
WARNING: Cleaning polygons, result is not guaranteed!
Building topology …
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points … 32086
All points (vertices): 60925
Registered points (unique coordinates): 32086
Points marked for break: 1136
Breaks: 3050
Remove duplicates:
Duplicates: 1496
Break boundaries:
Intersections: 0
Remove duplicates:
Duplicates: 0
Clean boundaries at nodes:
Modifications: 0
Change boundary dangles to lines:
Removed dangles: 0 changed lines: 0
Change boundary bridges to lines:
Removed bridges: 0 changed lines: 0
Building topology …
423 areas built
3 isles built
Topology was built.
Number of nodes : 1136
Number of primitives: 3473
Number of lines : 0
Number of boundaries: 3473
Number of areas : 423
Number of isles : 3
Number of areas without centroid : 423
Building topology …
1979 primitives registered
423 areas built
3 isles built
Topology was built.
Number of nodes : 1559
Number of primitives: 1979
Number of points : 423
Number of lines : 0
Number of boundaries: 1556
Number of isles : 3
423 input polygons
Windows Live™: Keep your life in sync. Check it out.
