I am perplexed by some odd scripting behavior and am hoping that someone can point out the (probably stupid) mistake I am making.
I use a simple for loop with g.mlist an r.what to query some climate data. I have run this script before and never had any trouble with it. However, today I notice that it is returning fewer data points from my climate data than the number of coordinates that I am querying. For example I have a file "coords" that contains 8973 lines of coordinates. This should return 8973 lines of data from grass. However, the script is returning 8925 lines of data. I'm not getting any errors and can think of no reason the script should behave this way.
Any ideas?
Here is a copy of my shell script
#!/bin/bash
#test to see if script is being run from GRASS
if test "$GISBASE" = ""; then
echo "You must be in GRASS to run this program"
exit
fi
# Use input text file for coords in the format: lon lat (easting northing) single
# space between coords. Example: -98.42072 55.91481. Must use real coordinates, no blanks.
# Script will create file for each $MAP in the list. g.mlist can also take the "pattern"
# argument which takes regular expressions. For example: pattern="*" returns all
# maps in the database.
for MAP in `g.mlist type=rast pattern="HIST_bio_12"`; do
r.what --verbose input="$MAP" < ~/Desktop/worldclim/coords > ~/Desktop/worldclim/"$MAP".txt;
echo "$MAP"
done
Are some of the data points missing? That would be my first guess.
HTH,
Stephen
Any ideas?
#!/bin/bash
exit
fi
r.what --verbose input="$MAP"< ~/Desktop/worldclim/coords> ~/Desktop/worldclim/"$MAP".txt;
echo "$MAP"
done
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
http://www.auburn.edu/~sas0025
Let's not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals.
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
Thanks Stephen
I just found the problem… bloody meta character "^M" that did not show up in my text editor. I opened the coords file with vi and there it was!
krw
HTH,
Stephen
Any ideas?
#!/bin/bash
exit
fi
echo "$MAP"
done
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
-K. Mullis
-Robert Gentleman
