unfortunately I added 'rm .* ' instead of a 'rm $variable.*' in a GRASS
script, hence I had to setup a new user account but when starting grass63 as
the new user I get:
sh-3.1$ grass63
Cleaning up temporary files.....
Starting GRASS ...
GISDBASE='/data1/grassdb_africa';
LOCATION_NAME='HI';
MAPSET='nlm';
ERROR: The SHELL variable is not set
I never encountered it when installing Linux/GRASS for the first time, I
searched a bit and found some GRASS shell scripts with this error message but
I couldn't find a hint how to fix that.
Is is a GRASS or Linux specific problem? Any idea which SHELL variable I have
to set? And how to do so?
Martin
P.S.:using 6.3 cvs access hence pretty "old" and Debian testing GRASS version
Is is a GRASS or Linux specific problem? Any idea which SHELL variable I have to set? And how to do so?
I'm not sure, but I think you have to set just the SHELL variable. Try to check in this way: 'echo $SHELL'. If you get nothing then you can set it to '/bin/bash' in the terminal you are using. If you want to set it permanently, try this: chsh -s /bin/bash. You can use BASH or whatever other shell you like.
I hope this helps,
Roberto.
Roberto Antolín Sánchez
Politecnico di Milano - Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 - 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
roberto.antolin@polimi.it
On Jan 28, 2008 6:15 PM, Martin Wegmann
<wegmann@biozentrum.uni-wuerzburg.de> wrote:
Hello,
the new user I get:
sh-3.1$ grass63
Starting GRASS ...
LOCATION_NAME='HI';
MAPSET='nlm';
I am afraid that this is a local problem:
The relevant bit is in the start script:
# check for SHELL
if [ ! -x "$SHELL" ] ; then
echo "ERROR: The SHELL variable is not set" 1>&2
rm -f "$lockfile"
rm -rf "$tmp" # remove session files from tmpdir
exit 1
fi
The $SHELL variable is set when you login: example:
[neteler@localhost ~]$ echo $SHELL
/bin/bash
IMHO something is still messed up with your user account.
Am Montag, 28. Januar 2008 19:17:12 schrieb Roberto Antolin:
Hello Martin and all,
the new user I get:
sh-3.1$ grass63
Starting GRASS ...
LOCATION_NAME='HI';
MAPSET='nlm';
SHELL should be set from the last field in the user's /etc/passwd
entry[1] by any program which creates a session, e.g. login for
console logins, xdm/gdm/kdm for X sessions, sshd for ssh logins, etc.
[1] To be precise, the value of the pw_shell field in the "passwd",
structure returned by getpwnam() or getpwuid(). Some systems use e.g.
NIS or LDAP for storing user accounts instead of /etc/passwd.
The standard way for a user to change their shell is with the "chsh"
command.
