to calculate the shortest path from a mountain top into the valley, I
ususally use r.flow, but what if I do not want the shortest but the less
steepest path?
thanks,
Georg
On Tue, 17 Feb 2009 13:39:15 +0000, Georg Kaspar wrote:
ususally use r.flow [...]
sorry, I meant r.drain...
Forgot to post to the list as well,
In short, combine both the length cost map and the steepness (r.slope
output) cost map (according to your preference).
Use this output as input for a final cost calculation.
That should do the trick I think,
Koen
> Hi,
> ususally use r.flow [...]sorry, I meant r.drain...
grass-user mailing list
grass-user@lists.osgeo.org
