[GRASS-user] Shortest path for a new road
Hi!
I need to create a plan for a new road from a known source point, to a known destination area. I have a grid of elevation and land use for the region. So from that I can calculate a cost weight using r.walk or r.cost Now by using this I'd like to calculate a new raster or vector which would show the least cost path from source to destination.
Is this possible? I know that with Arc/Info I can use the Spatial Analyst to do this, but I'd like to be able to do it with GRASS. Any ideas?
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
On Friday 26 January 2007 03:12, Wolf Bergenheim wrote:
Hi!
--Wolf
Hi Wolf,
The usual approach in GRASS for this type of problem is:
1. define cost surface (slope is commonly used) but a distance map would work
as well (r.mapcalc "dist = 1")
2. create cumulative cost map (r.cost) along with the cost surface from step 1
3. simulate a drop of water 'draining' from some destination to the point of
least cost (your starting point) (r.drain)
4. use r.to.vect to vectorize the output from r.drain.
rather verbose example here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/244
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Use r.drain with your cost surface (made from the destination point) and the
source point.
Michael
On 1/26/07 4:12 AM, "Wolf Bergenheim" <wolf+grass@bergenheim.net> wrote:
Hi!
--Wolf
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Dylan Beaudette wrote:
Hi Wolf,
1. define cost surface (slope is commonly used) but a distance map would work as well (r.mapcalc "dist = 1")
I ended up using slope + some other costs added with r.mapcalc to a cost surface.
This was the crucial step that I had somehow missed. Thank you very much! You have made me a very happy man!
--Wolf
> for the region.
from step 1
point of least cost (your starting point) (r.drain)
see also the "GRASS Seeds" Leicester raster tutorial for an example.
  http://grass.itc.it/gdp/tutorials.php
Hamish
