[GRASS-user] Should the location or mapset be created everytime?
sorry I dinot describe exactly.
I am working on a webservice which intend to handle data(mainly are the HDF4,) by grass,since the grass do not support the hdf,then I try to transfer the hdf4 to geotiff with gdal ,then import the tif to grass,the problem comes out ,should I create a new location and mapset for each geotiff each time??
ps:
If my current location is usa ,and I import a tif of china ,what can happen? If I should creat a new loaction but I have not seen the tif before and I donot know the location then how to do ?
hi,
ps:
you can find out, what the raster uses for coordinate system using
gdalinfo utility
you can also create new location according to the raster/vector map,
like
1) start grass in *any* location
2) run r.in.gdal location=NEW_LOCATION
3) switch to your new created NEW_LOCATION
j
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299 ED8A C8AB 74B8 08D4 E08F
