but how does a pyhton script look like for this command?
I first need to define my location and my mapset and I have to import or define somehow the variable river. How do I set the region? In Grass I just do g.region vect=river res=10 save=region_river.
Can someone just give me an example for these two commands and how such a .py will look like...
Thank you very much
Johannes
Sicherer, schneller und einfacher. Die aktuellen Internet-Browser -
jetzt kostenlos herunterladen! http://portal.gmx.net/de/go/atbrowser
After reading the grass-website about python scripts, I still don't know how to start. I just want to create a .py file which i than want to run.
This python script should do following simple grass command:
v.to.rast input=river output=river_raster use=val value=1 --o
use run_command from `core` module [1].
grass.run_command('v.to.rast', overwrite = True, input = 'river',
output = 'river_raster', use = 'val' value = 1)
