[GRASS-user] Simulation in grass 6
Hi
I am planning to write a spatial simulation model, simulating the spread of alien species on a landscape scale by using grass.
My question how I should write the simulation model, i.e. in which scripting language. I am using Linux and have quite a bit of experience with R, so I thought that R (together with spgrass6) would be a nice scripting language to write the simulation and sending the grass commands through to grass, because it offers me quite a bit more concerning strtucturing on the modelling side then using a normal shell script
But the simulation should also run under Windows and I don't have any experience with grass and R under windows.
I have the following questions:
1) Does R and grasswork together (via spgrass6) under windows as they do under Linux?
2) Is there anything I have to look at when writing a simulation model
under Linux which should also run under Windows?
3) Is any other scripting language more suitable for what I want to achieve (I have no experience with C / C++, but quite a bit with Delphi. I have never used the likes of perl et al. and bash scrips seem a bit awkward to me for bigger projects.)?
Thanks in advance for your help,
Rainer
NEW EMAIL ADDRESS AND ADDRESS:
Rainer.Krug@uct.ac.za
RKrug@sun.ac.za WILL BE DISCONTINUED END OF MARCH
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
Biology (UCT)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
Tel: +27 - (0)21 650 5776 (w)
Fax: +27 - (0)86 516 2782
Fax: +27 - (0)21 650 2440 (w)
Cell: +27 - (0)83 9479 042
Skype: RMkrug
email: Rainer.Krug@uct.ac.za
         Rainer@krugs.de
script
It sounds very well suited for Linux or MacOSX, but I've little idea about the
GRASS+R Windows situation. Maybe someone on the statsgrass mailing list knows?
(taking the liberty to cc)
You could try python. The next version of GRASS will use python heavily for the
GUI, so expect lots of example scripts, help on the mailing list from fellow
travelers, and tight integration with the code.
Learn python in 10 min: http://www.poromenos.org/tutorials/python
Also there is a SWIG/Python interface to any needed GIS library functions,
which is pretty cool, although the grass modules generally give you what you
need without having to resort to using any low-level libgis functions.
see http://grass.gdf-hannover.de/wiki/GRASS_and_Python
     http://freegis.org/cgi-bin/viewcvs.cgi/grass6/swig/python/
Hamish
      ____________________________________________________________________________________
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search
http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz
Thanks a lot - I am subscribed to this list now - strange that I overlooked that lisat before...
Sounds very interesting - I'll take a look at it.
Python doesn't look as difficult as I thought the first time I looked at it (a few years back...). Looks similar to what I am used to in Delphi.
Looking at the document, I must say it seems to be a usefull approach to use Python - and it is crossplatform. One thing which I did not see that quickly is how I can execute grass commands from python - I guess it is easy, but I didn't find it when I looked at the document.
Thanks a lot for your usefull and very helpfull hints,
Rainer
Hamish
Luggage? GPS? Comic books? Check out fitting gifts for grads at Yahoo! Search
grassuser mailing list
grassuser@grass.itc.it
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
Actually, I often use R as an scripting language
for grass. The problem is that grass commands have
to be issued using system(), which, for a complex code,
becomes inconvenient (lots of paste() for generating the
actual grass command).
Not being an expert at all on python, I wonder
if making R able of executing grass commands without
having to use system() could not be a valid alternative
to python, at least in some cases.
Anyway, I think that the real solution would be having a GIS
able of displaying R objects, sort of RGis.
Agus
Hamish
statsgrass@grass.itc.it
http://grass.itc.it/mailman/listinfo/statsgrass
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo@ija.csic.es
http://www.ija.csic.es/gt/obster
This is indeed a hassle, but I wrote a small R function which is pasting all the parameters supplied together and executing them via system() - still not perfect, but it works nicer then the system(paste(...)) approach.
I think this would, at least, make using grass from R much easier. And it shouldn't be to dificult to do that - just defining a function with the same name as in R and execute it via system() - I think about using this in my simulation.
Rainer
Agus
Hamish
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
I don't know if this will help you.
Just thinking about your reasons to use windows, maybe it's because you
need to execute some windows program.
My solution is to use R-GRASS in Linux for simulation, what is excellent
beacuse of the wealth of R functions for statistical evaluation of the
models, and the matrix operations in R. Also you can call C compiled
code from your R script to speed up bottlenecks in your code, as pieces
with a lot of loopings etc.
And if you need to execute some windows program, you can also execute
them remotely in a windows machina via ssh and get bak your results to
your linux machine. This also works right.
Good luck
Javier
Agus
about the
list knows?
heavily for the
fellow
functions,
what you
Hamish
Yahoo! Search
Javier García-Pintado
Institute of Earth Sciences Jaume Almera (CSIC)
Lluis Sole Sabaris s/n, 08028 Barcelona
Phone: +34 934095410
Fax: +34 934110012
e-mail:jgarcia@ija.csic.es
Hamish:
Rainer:
I defer to the GUI programmers to answer that.
no worries.
Hamish
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us. http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
Hamish wrote:
Hamish:
Rainer:
For information on running external commands from Python, see:
  http://docs.python.org/lib/module-subprocess.html
Avoid using the older os.* functions. Section 17.1.3 lists equivalents
using the Popen() interface, which is more robust (particularly on
Windows).
Ranier,
script
You might want to take a look at the wildfire modeling routines already in
GRASS. I think that with minimal work, these could be modified to become
general spread-modeling routines. I've used these (with some difficulty) to
model the spread of other phenomena than wildfires and would love to have
general spread routines in GRASS.
the
Hamish
I also want to second Hamish's mention of Python. It is a powerful and
(relatively) easy to learn language that will become increasingly important
to GRASS in the future. Extensions scipy and numpy give it additional
abilities.
Michael
______
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
No - I am absolutely happy with Linux and would prefer to not have to think about windows any more - but there is always somebody who is paying you, in my pase the one who contracted us. They want to use it finally under windows...
Rainer
SNIP
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
Rainer
SNIP
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
Glynn Clements wrote:
Hamish wrote:
Hamish:
Rainer:
Windows).
Thanks a lot - I will take a look at them.
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
Michael Barton wrote:
Ranier,
script
Good idea - I haven't thought about them. I'll see what I can do with them.
the
Hamish
abilities.
Michael
______
phone: 480-965-6213
fax: 480-965-7671
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
I might soon have some time available to look into modifying
r.wildfire and generalizing it for applications in archaeology,
human geography ... or astrobiology.
Do you have any pointers to publications that I could look into
as a starting point for some inspiration?
Benjamin
Ranier,
script
the
Hamish
abilities.
Michael
______
phone: 480-965-6213
fax: 480-965-7671
Benjamin
Ranier,
script
the
Hamish
abilities.
Michael
______
phone: 480-965-6213
fax: 480-965-7671
