Daniel wrote:
What do you mean, r.sun can do multithreading? I've heard that
r.sun uses multithreading in GRASS 7, but is that implemented
in GRASS 6? Or are you talking about "poor man's
multithreading," like on the GRASS wiki?
there is OpenCL GPU accel. support, but it has not yet been
merged into grass 7. (mea culpa)
for r.sun being run 365 (or whatever) times in a row the "poor
man's" method is fine, in fact the r3.in.xyz script in addons
is perhaps the most efficient multi-CPUing in grass to date.
(to my surprise)
I've just read through the r.horizon code in devbr6 and I don't
see anything which makes the module unable to be run multiple
times in the same mapset. (no external region setting, no
generically named temp files, no gratuitous use of grass library
global variables) ... are you running under NFS or similar as
addressed by Markus's script? aka maybe the trouble is rooted
elsewhere?
I did a little debugging today and think it's due to the large
size of my study area (~36 km², 0.5m resolution).
72000x72000, how much ram does r.horizon use?
maybe processes are being killed as you run out of RAM.
in that case set max num of parallel jobs so that it fits
into memory without going into swap space instead of num of CPUs.
and error handling in the script (test for '$? -ne 0') could
help try failing runs again.
If I spatially partition the area and then stitch everything
back together, I hope it works - tests on smaller regions have
worked correctly thus far but I'll need to wait a while to see
the real results.
for r.horizon the mountains in the distance can matter (that's
the whole point) so I'd be careful with cutting up the region.
temporarily lowering the region resolution during r.horizon
may be less-bad of a compromise.
FWIW I've tentatively given up on using r.horizon, see the "r.sun
commissioning trials" trac ticket and wiki page. since sun
placement changes each day, and for sub degree placement of the
sun you need so many horizon maps as to make the loading of them
all more expensive than just re-calculating it on-the-fly but
with the exact placement. (I generally try for slow exactness
instead of fast processing time though, YMMV)
but maybe I don't correctly understand what r.horizon is doing..
Hamish
