Hi All,
I just downloaded 8.0.0.RC2 source code for Linux from https://github.com/OSGeo/grass/releases/tag/8.0.0RC2 to try it out today, everything compiled and built fine.
I’m not seeing any single-window GUI or options to enable it; did I install the wrong branch?
Eric
Nevermind, I see that I had to git clone the main branch. The single-window GUI looks great! I really look forward to using this.
I still don’t see any options for dark mode, though - where do I find this?
Eric
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Thursday, January 20th, 2022 at 23:23, Eric Patton via grass-user grass-user@lists.osgeo.org wrote:
Hi All,
Eric
neteler
January 21, 2022, 11:04am
3
On Fri, Jan 21, 2022 at 4:58 AM Eric Patton via grass-user
This reminded me of the fact that this directory isn't populated yet:
https://grass.osgeo.org/grass81/source/
I have now created a new cronjob, once approved, GRASS GIS 8.devel
(currently 8.1.dev) will be generated:
https://github.com/OSGeo/grass-addons/pull/682
Coming soon!
Hi Eric,
You need to change the appeareance
settings to a dark one, and grass will get it. At least, that’s how it worked for me.
HTH,
Vero
El vie, 21 ene 2022 a las 4:59, Eric Patton via grass-user (<grass-user@lists.osgeo.org >) escribió:
Eric
On Thursday, January 20th, 2022 at 23:23, Eric Patton via grass-user <grass-user@lists.osgeo.org > wrote:
Hi All,
Eric
grass-user mailing list
done:
... this folder now contains the GRASS GIS 8.1.dev source code
snapshot, the new cronjob is up & running to generate it weekly.
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://courses.neteler.org/blog
Hi Vero,
Did you mean the Appearance tab under GUI settings? There is nothing controlling color in this tab that I see, but under the Map Display tab, there is the background color selector. Changing that only changes the background of the map display window, not the GUI toolbar background.
Eric
On Friday, January 21st, 2022 at 08:03, Veronica Andreo veroandreo@gmail.com wrote:
Hi Eric,
HTH,
Vero
Eric
Hi All,
Eric
Oh, sorry that I wasn’t explicit enough.
I meant the appearance in your operative system. In my fedora box is under Applications or Start → settings → appearance, and there, in the Style tab, I see adwaita, adwaita dark and such… Once you pick one of the dark themes among the options, grass will get it too
El vie., 21 ene. 2022 17:20, Eric Patton <eric.r.patton@protonmail.com > escribió:
Hi Vero,
Eric
On Friday, January 21st, 2022 at 08:03, Veronica Andreo <veroandreo@gmail.com > wrote:
Hi Eric,
HTH,
Vero
Eric
Hi All,
Eric
