[GRASS-user] Single GUI window in 8.0.0RC2?
Veronica Andreo:
Oh, sorry that I wasn't explicit enough.
I meant the appearance in your operative system. In my fedora box is under
Applications or Start --> settings --> appearance, and there, in the Style
tab, I see adwaita, adwaita dark and such... Once you pick one of the dark
themes among the options, grass will get it too :slight_smile:
tested here in the MS windows side of the world :wink: .... switched the windows 10 box into dark mode
many software packages like Word, notepad++ etc are then in dark, unfortunately not winGRASS 8 ....
kind regards
Helmut
(attachments)
On Sat, Jan 22, 2022 at 3:39 PM Helmut Kudrnovsky <hellik@web.de> wrote:
Veronica Andreo:
Oh, sorry that I wasn’t explicit enough.
Applications or Start → settings → appearance, and there, in the Style
tab, I see adwaita, adwaita dark and such… Once you pick one of the dark
tested here in the MS windows side of the world :wink: … switched the windows 10 box into dark mode
many software packages like Word, notepad++ etc are then in dark, unfortunately not winGRASS 8 …
I was not aware of that, but you are right. I tested it and even File Manager doesn’t support it (at least in the version I used), read more here:
https://forums.wxwidgets.org/viewtopic.php?f=23&t=45869
kind regards
Helmut_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
