[GRASS-user] Sites/Points File Input
   There have apparently been changes from version 5.x to 6.4 in how point
data are entered. No longer are there the 's.' functions (e.g., s.in.ascii),
so we use the v.in.ascii function now. The man page lays out the options,
but I would like a reality check on the input data format I created using
the book (2nd ed) as a guide (pages 80-81):
cat|longitude|latitude|name
1|122:30:32.43W|45:19:19.49N|@"Lockie property"
2|122:30:17.92W|45:18:52.45N|@"Mompano Dam spillway"
3|122:29:34.08W|45:18:47.16N|@"OR-CC-8"
   If this format is still valid, I propose the following command:
v.in.ascii -b input="sites.txt" output="keyPts" format="point" skip=1 \
columns='cat int, x double, y double, name varchar(20)' x=1 y=2 cat=0
   I don't have a region yet defined; I should get this figured out first.
But I still need to get the correct data file format and command line
syntax.
Rich
On Fri, Nov 20, 2009 at 11:06 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
almost.
- take out @
- take out "" (if you want)
- call the first column "id" rather than "cat" which is internal
   (indeed, you don't need that column)
notes:
- x is 2nd column etc.
- -b is no good. It is only for GB of Lidar data since most GRAS modules
   want topology to be present
- cat=0: don't use it since we let v.in.ascii generate the cat column
- use "..." for columns=
So it would be:
id|longitude|latitude|name
1|122:30:32.43W|45:19:19.49N|Lockie property
2|122:30:17.92W|45:18:52.45N|Mompano Dam spillway
3|122:29:34.08W|45:18:47.16N|OR-CC-8
v.in.ascii input="sites.txt" output="keyPts" format="point" skip=1 \
              columns="id integer, x double precision, y double precision, \
              name varchar(20)" x=2 y=3
v.db.select keyPts
cat|id|x|y|name
1|1|-122.509008|45.322081|Lockie property
2|2|-122.504978|45.314569|Mompano Dam spillway
3|3|-122.4928|45.3131|OR-CC-8
Hope that helps,
On Fri, 20 Nov 2009, Markus Neteler wrote:
Hope that helps,
Markus,
   Yes it does, and that's why I wanted a check before proceeding.
Danke,
Rich
