[GRASS-user] Sky-view Factor and GeoTiff Histogram equalization (stretch)
Hello to the GRASS users,
Does anybody know how to equalize, or stretch, the histogram of a raster? The last represents Sky-view Factor based on a DEM model. It is well-known visualization technique when looking for archaeological structures.
I have to do minimum-maximum stretch of the histogram with saturation of minimum. How to do this in GRASS? Any help will be highly appreciated! Thank you!
Greetings,
Adrian Kirilov
Hello Adrian,
raster?
In general, you can perform histogram equalisation on any GRASS raster map's
color table by using the "r.colors" module and instruct the "-e" flag. The "-
e" flag (quoting from its manual) "is designed to work with any color table,
both the floating point and the integer raster maps".
Please have a look in the manual (grass64):
<http://grass.osgeo.org/grass64/manuals/r.colors.html&gt; (or grass70:
<http://grass.osgeo.org/grass70/manuals/r.colors.html&gt;\).
Note, this will operate on the color table associated with the raster map in
question. It wont affect the map's actual pixel values.
structures.
     I have to do *minimum-maximum stretch of the histogram with saturation
of minimum*. How to do this in GRASS? Any help will be highly appreciated!
I don't know what the "...with a saturation of minimum" means. Maybe someone
else that understands this stuff better can help.
Best, Nikos
> saturation of minimum*. How to do this in GRASS? Any help
Nikos:
means. Maybe someone else that understands this stuff better
can help.
the "stretch" sounds a bit like linear 0.0-1.0 normalization to me.
for an application, see also the i.landsat.rgb module.
Hamish
Nikos:
> can help.
Hamish:
Also, there is "r.rescale.eq". Maybe also of interest here? @Adrian,
r.rescale.eq will operate on the actual pixel values and create a new raster
map as requested, e.g.:
r.rescale.eq input=InputMap output=RescaledMap to=0.0,1.0
Best, Nikos
