[GRASS-user] slope calculation under lat long
I wondering if the slope calculation in GRASS
(https://grass.osgeo.org/grass78/manuals/r.slope.aspect.html) take in to account the
latitudinal change of the meridian distance or just simply treats the raster as square grids also under lat long system (WGS84)?
In case of “treats the WGS84 raster as square grids” the only solution to obtain better results is to resampling the DEM to UTM or to Equi7.
Thank you
Giuseppe
Giuseppe Amatulli, Ph.D.
Research scientist at
School of Forestry & Environmental Studies
Center for Research Computing
Yale University
New Haven, CT, USA
06511
Teaching: http://spatial-ecology.net
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
On 19/03/20 16:37, Giuseppe Amatulli wrote:
AFAIK, r.slope.aspect uses the G_distance() function which calculates geodetic distance if in a Lat-Long location, so yes it takes into account latitudinal change.
If it doesn't, I would consider this a bug.
Moritz
Thanks Moritz,
my understanding on this is that a pixel with delta elevation of 100m will create different slope values due to the change of the Pixel dimension going from the equator to the north location.
This observation is valid for the east-west slope because of the distance change in the x dimension, rather for the north-south slope the y dimension stays constant and so the slope remains the same.
In other words, is there any other correction that will take this in to account?
Thank you
Giuseppe
Yale University
New Haven, CT, USA
06511
