[GRASS-user] Snap across layers
Hello everybody,
anyone knows if is possible to do snap across different layers in Grass 6.3?
Thanks
Luca
hi Luca,
- v.edit does it:
      bgmap Name of background vector map(s) snap to
- the new digitizer in wxgrass does it (not yet enabled by default)
On Jan 28, 2008 3:29 PM, Luca Casagrande <luca.casagrande@gmail.com> wrote:
Hello everybody,
Thanks
Luca
Markus Neteler ha scritto:
hi Luca,
- v.edit does it:
Hello everybody,
Thanks
Luca
Hi Markus and thanks for your answer.
Before moving to my data, I am doing some tests with 2 vector layers:
http://img337.imageshack.us/my.php?image=schermatamapdisplay1vp5.png
Basically the small one, should snap to the bigger one.
The command line I use is this:
v.edit map=origine bgmap=destinazione cat=1-999 tool=snap thresh=-1
But nothing change.
In the log I have got a lot of line like this, both if i set thresh -1 or 500
D1/1: Vect_set_thresh(): thresh = 0.000000
Thanks for your help
Luca
2008/1/28, Luca Casagrande <luca.casagrande@gmail.com>:
> - v.edit does it:
Luca:
But nothing change.
or 500
tool 'snap' in v.edit uses library fn Vect_snap_lines() which doesn't
support snapping to the vector features from background map layer.
Snapping mode (no, node, vertex) and background map option works
currently only for tool='add'. For now, try to create an empty vector
map, export to ascii format the map you want to modify and update the
empty map, e.g.
v.edit a3 tool=create
v.out.ascii a2 format=standard | v.edit a3 tool=add bgmap=a1 id=1-999
thre=500 snap=node
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Hi Martin and Luca...
I have just tried with v.out.ascii as you suggested...
I have two test vector layer ("pippo" and "pippo1")
each one contains only one area (without centroid)
they are really similar and vertex are quite near each other (~30
meters)
I have tried these commands:
v.out.ascii pippo1 format=standard | v.edit a3 tool=add bgmap=pippo
thre=200 snap=vertex
it works but, at the end I obtain only a copy of the first map (i.e.
"a3" is exactly equal to "pippo1")
It seems that only "add" works... but not the snap and the threshold...
any suggestion?
many thanks
Ivan
Il giorno mar, 29/01/2008 alle 15.52 +0100, Martin Landa ha scritto:
> > - v.edit does it:
Luca:
> But nothing change.
> or 500
empty map, e.g.
thre=500 snap=node
Martin
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
ok...
solved...
the bgmap must be a map of nodes... (I have obtained it with v.to.points
-v)
then all works fine...
thanks
meters)
any suggestion?
many thanks
Ivan
> Hi,
> > > - v.edit does it:
> Luca:
> > But nothing change.
> > or 500
> empty map, e.g.
> thre=500 snap=node
> Martin
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
