[GRASS-user] Snapping river segments
I'm trying to extract only the largest rivers from a very detailed
hydrology map (mostly for display purposes). Right now the map just
looks black with lines. I've managed to use v.extract for areas but
since the rivers are in segments i can't use v.extract for lengths.
I've tried v.clean snap but it doesn't seem to be doing what I want it
to. Any advice?
-Colin
to. Any advice?
-Colin
grassuser mailing list
grassuser@grass.itc.it
for now (with my previous experiences with exactly the same problem) v.digit seems to be the fastest solution :frowning:
With over to 10,000 river segments that isn't exactly a practical
solution for me. Anything else?
On 3/22/07, Jarek Jasiewicz <jarekj@amu.edu.pl> wrote:
Colin Nielsen napisa³(a):
> to. Any advice?
> -Colin
Perhaps v.to.db to add the length of each segment to the database, and
then v.extract? or SQL thru gis.m to create a new map?
Carlos
> > to. Any advice?
> > -Colin
> > _______________________________________________
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Carlos
it is not a good solution there are no rules on segment lenght in river network (there can be short segement in main stream and longer in tributaries and opposite)
> Colin Nielsen napisa�(a):
> > to. Any advice?
> > -Colin
well problem is on
What if you convert the vector to raster, then back to vector? each
stream should be one segment.
> Carlos
>> want it
>> > > to. Any advice?
>> > > -Colin
well problem is on
_________________
> to. Any advice?
> -Colin
have you some addational atributies on segment?
It is digitised map (it produced a segment between every juncion) without categories and another atributies?
If so, there is no solution in grass (IMHO), but you can search solution in JGRASS in tool called horton machine it seems it will help you, also look for solution in TAS (Terrain analisys system WINDOWS only, free strahler analisys) or maybe the best fot this TauDEM free extension for ArcGIS (not free) and Mapwindow (free), but I don't guarantee success.
or it is regulral hydrological map with adational attributies if so there shall be some addational atributies like hydrological id or name, SQL shall help
cherrs
Jarek
no, there be much more addational segments. Wrong way. (about twice, as I tried few seconds before)
> Carlos
>> want it
>> > > to. Any advice?
>> > > -Colin
well problem is on
to. Any advice?
v.build.polylines
There are bugs in 6.2 in this module (easy to workaround, and fixed for
good in 6.3 by Martin Landa):
https://intevation.de/rt/webrt?serial_num=4249
Workaround: run 'v.clean tool=prune thresh=0' on the v.bulid polylines
output. It will remove the bogus doubled vertices.
https://intevation.de/rt/webrt?serial_num=4247
Applies only to boundaries anyway.
After you transform segmented lines into polylines you should be able
to use v.extract by length.
Maciek
