Dear Markus,
Excellent! Thanks to everyone for their help.
I tested r.diversity in the new revision (61840) on a raster with 12933032 cells and it took under 3 minutes to complete r.li.simpson, r.li.shannon, r.li.pielou and r.li.renyi outputs.
Amazing
execGRASS("r.diversity",flags="overwrite", parameters=list(input="flow", prefix="flow_div", alpha=0.5, size=3))
r.li.simpson complete. Raster map <flow_div_simpson_size_3.0> created.
r.li.shannon complete. Raster map <flow_div_shannon_size_3.0> created.
r.li.pielou complete. Raster map <flow_div_pielou_size_3.0> created.
r.li.renyi complete. Raster map <flow_div_renyi_size_3.0_alpha_0.5>
created.
Done.
Thanks again and keep well.
Sandra
-----Original Message-----
From: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] On Behalf Of Markus Neteler
Sent: 06 September 2014 05:15 AM
To: Sandra MacFadyen
Cc: GRASS user list; Duccio Rocchini; Luca Delucchi
Subject: Re: [GRASS-user] execGRASS("r.diversity") Done. No rasters created (Large rasters)
Dear Sandra,
On Fri, Jun 20, 2014 at 7:49 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Sat, Jun 14, 2014 at 9:21 AM, Sandra MacFadyen <sandramf@live.co.za> wrote:
I am using r.diversity (GRASS GIS 7.0.0svn build 60785 win32) through
R (R version 3.0.2 win32) on Windows 7 64bit.
However, when running the same code on a larger image (cells=6746328)
from my own location, although it reports Done, no rasters are
created. If I subset the image
(cells=1632830) and run it again its works (see # sub2Kruger # code and results below).
So I'm guessing it is a memory issue?
... it consumes a lot of memory... will check on a bigger machine,
perhaps a memory leak.
The assumption turned out to be right and I think we got it today!
Vaclav Petras checked it and discovered an "unfortunate" memory allocation which he fixed in r.li.* in revision http://trac.osgeo.org/grass/changeset/61812 ("r.li: fix memory handling (memory leak in avl_to_array function))".
Now r.li has become very fast, on my laptop:
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.region -p rast=lsat5_1987_10 res=10 -a ...
rows: 1355
cols: 1503
cells: 2036565
GRASS 7.1.svn (nc_spm_08_grass7):~ > time -p r.li.simpson --o input=lsat5_1987_10@landsat conf=conf_diversity_5.0
output=lsat5_1987_div__simpson_size_5.0
r.li.simpson complete. Raster map <lsat5_1987_div__simpson_size_5.0>
created.
--> 29.32 seconds
or with a simulated higher resolution:
res=5 -aprojection: 99 (Lambert Conformal Conic) ...
rows: 2708
cols: 3005
cells: 8137540
created.
--> 227.37 seconds (used to be > 2 hours)
So, to grab this improvement for Windows, grab the version from here:
http://wingrass.fsv.cvut.cz/grass71/
(or via OSGeo4W installer). Be sure that the revision is at least
r61812 which is indicated in the file name.
Please let us know if all works to avoid that the change has any negative impact.
Tests here did not show any changes in the output except for the speed improvement and solved memory leak.
Subsequently also r.diversity should behave now.
I'll backport it to GRASS 7.0 release branch after some testing.
