[GRASS-user] [SOLVED] was Moving GISBASE box2box
Cassiel wrote:
Moving from the old machine on the removable drive and from
the latter to the newer machine changed the case of the VAR
and WIND file inside the location dirs. What sounds very
strange to me is why only those two files plus a MYNAME
one...
Moritz:
Did you have other upper-case names which remained upper-case ?
Maybe an issue with a fat filesystem on the removable drive ?
Cassiel:
Yes, DEFAULT_WIND, PROJ_INFO, PROJ_UNITS remained upper
case while (I checked the rest of locations) all wind and
var files were converted to lower case.
The removable drive is fat32 and file permissions are all
755 on the older linux box...
the above 3 don't fit into DOS's 8.3 filename restriction, so
all get stored as PROJ_I~1 etc. with the real name stored
elsewhere. VAR and WIND are less then 8 letters so just get
stored as normal DOS names, which are case insensitive. If you
look in the man page for 'mount' I think you will find a few
options (-o ...) for choosing how to deal with uppercase letters
while visiting fat-land.
Hamish
2009/4/9 Hamish <hamish_b@yahoo.com>
one…
Moritz:
Cassiel:
755 on the older linux box…
the above 3 don’t fit into DOS’s 8.3 filename restriction, so
look in the man page for ‘mount’ I think you will find a few
options (-o …) for choosing how to deal with uppercase letters
Hamish
Ok, I would have never guess that, as you can see there are no names containing ~ char looking the output below.
I wonder if some mkfs.vfat option can override this behaviour, clearly I remember that during the last year I did backup regularly from work to home without having troubles.
regards
r
rmorelli@debian:/$ ls -lh /media/AMB-AGF2/mapserver/PERMANENT/
totale 256K
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 cats
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 cell
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 cellhd
drwxr-xr-x 5 rmorelli root 16K 9 apr 11:24 cell_misc
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 colr
drwxr-xr-x 2 rmorelli root 16K 2 dic 12:05 dbf
-rwxr-xr-x 1 rmorelli root 350 26 nov 2007 DEFAULT_WIND
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 fcell
drwxr-xr-x 2 rmorelli root 16K 5 set 2007 g3dcell
drwxr-xr-x 2 rmorelli root 16K 9 apr 11:24 hist
-rwxr-xr-x 1 rmorelli root 12 19 dic 2006 myname
-rwxr-xr-x 1 rmorelli root 139 19 dic 2006 PROJ_INFO
-rwxr-xr-x 1 rmorelli root 38 19 dic 2006 PROJ_UNITS
-rwxr-xr-x 1 rmorelli root 61 17 mar 14:16 var
drwxr-xr-x 14 rmorelli root 16K 1 apr 15:47 vector
-rwxr-xr-x 1 rmorelli root 321 1 apr 15:39 wind
