Hi everyone,
I hope you can help me in solving this issue. Basically, what I want to do is to
create a new raster map whose cells are simply given by the "or" of other two
maps (possibly for specific categories), as follows:
r.mapcalc test=if(vegcover==1 || railroads==1)
However, maps like railroads are null() when not equal to 1. The resulting map
"test" is null() wherever cells in railroads are null(), therefore making
null() also cells where vegcover is 1.
How can I solve this issue?
Thanks!
Fulvio
Fulvio Mastrogiovanni
DIST|University of Genova|Italy
Email: fulvio.mastrogiovanni@unige.it
WWW: http://www.laboratorium.dist.unige.it/~fulvio/
Phone: (+39)0103532801
"Chi è abile nel sortire bizzarri stratagemmi è inesauribile come il
Cielo, la Terra e i grandi fiumi. Giunto al termine riparte, come il
Sole e la Luna; dopo morto rinasce, come le quattro stagioni."
you can use another if-clause,to test, if the other map is null using
"isnull(railroads)" eg.
Another way could be to use ||| (3x"|") to handle null-values
(for that see:
http://grass.itc.it/grass64/manuals/html64_user/r.mapcalc.html
section "sull support").
achim
Fulvio Mastrogiovanni schrieb:
Hi everyone,
Thanks!
Fulvio
You can change the NULL value using r.null map null=x to avoid the null()
handling. Is it your question..??
Christian.
Von: grass-user-bounces@lists.osgeo.org
[mailto:grass-user-bounces@lists.osgeo.org] Im Auftrag von Fulvio
Mastrogiovanni
Gesendet: Mittwoch, 1. April 2009 13:45
An: grass-user@lists.osgeo.org
Betreff: [GRASS-user] Some issues with r.mapcalc
Hi everyone,
is to
two
map
Thanks!
Fulvio
grass-user mailing list
