Im working with xyz data, the range of my data is: min = 0.046000 max = 1.358000
And I’m trying interpolate with r.surf.idw, but the answer is “Range of data: min = 1 max = 1”
I’m working with these steps:
r.in.xyz input=“biomarcadores.txt” output=“r_bio” method=“mean” type=“FCELL” fs=“|” x=2 y=1 z=4 zscale=1.0 percent=100
r.surf.idw input=r_bio output=r_sup_bio
The problem is when I try work with decimal numbers.
some advice about how I’ll work with decimal numbers in this process?
Thanks for your help!!
John
Grupo Bioestratigrafia - ICP
Bogotá - Colombia
Comparte tus fotos con tus amigos. Más fácil con Windows Live
Hi John,
I had the same problem. As Hamish told me some weeks ago,
"r.surf.idw and r.surf.idw2 only produce CELL (integer) maps."
I solved my problem multiplying the input raster by 100 (r_bio in your case), then I interpolated with r.surf.idw and finally divided once again by 100.
Hope this may help you
Alberto Pettazzi
MeteoGalicia - Departamento de Climatología y Observación
Consellería de Medio Ambiente e Desenvolvemento Sostible
Rúa de Roma, 6
15707 Santiago de Compostela. A Coruña
Teléfono: +34-881-999646
e-mail: alberto.pettazzi@meteogalicia.es <mailto:alberto.pettazzi@meteogalicia.es>
Jhon Ortiz escribió:
And I'm trying interpolate with r.surf.idw, but the answer is "Range of data: min = 1 max = 1"
I'm working with these steps:
r.in.xyz input="biomarcadores.txt" output="r_bio" method="mean" type="FCELL" fs="|" x=2 y=1 z=4 zscale=1.0 percent=100
some advice about how I'll work with decimal numbers in this process?
John
Bogotá - Colombia
Comparte tus fotos con tus amigos. Más fácil con Windows Live <http://download.live.com>
grass-user mailing list
grass-user@lists.osgeo.org
