I have two questions and maybe one solution.
When I am executing v.overlay (to clip my map with boundary line) I recieve always the clipped line (ainput is line, binput is area), however I need the polygon. When I switched first and second input layer, I had recieved an empty layer.
A little problem I have with v.buffer...the output is without attribut table. I was trying first v.buffer, then v.db.addtable and finaly v.overaly intersect with input line for buffer. But then is the output line again.
The problem with the spatial dissolve I did with the conversion to raster and raster to vector again. Every raster cell has value from the attribut (biotop code in my layer) and the conversion to vector again dissolved all other lines, only polygons boundaries stay on.
Thx for your help.
Martin
On 5/30/07, *Martin Besta* <martin.besta@googlemail.com <mailto:martin.besta@googlemail.com>> wrote:
I am new here and to grass, so I have some questions about working
with grass.
Hello and welcome to the fun world of open source GRASS GIS!!!
First,
I have some maps and one line, witch represents the boundary of
area. And I need to trim my maps with this line (somethings like
Clip by ESRI). Is it possible with Grass tools?
v.overlay will do a clip, inputting a line and a area as the "clipper". by selecting the "and" operator you will get the clipped lines.
Next...
To my polygon map I want to add some polygons from other polygon
map (Update, again like ESRI). I am not sure if v.patch is the
best solution to get this
v.patch should do the trick.
Next..
Can I edit the column header (name and type) of attribute table? I
know another WIN software that can it do, but i am interested in
GRASS now. Is it possible to remove some columns from the table
with Grass?
v.category looks like it edits attributes.
Sorry I cant be more definitive, but I'm working off of the old memory banks. =D
I would be happy if you could me give any answers.
Best regards
grassuser mailing list
grassuser@grass.itc.it <mailto:grassuser@grass.itc.it>
