I have been trying for a long time. Something wrong is going on. I appreciate if you can correct me.
I have all my source images in sinusoidal projection in a location called “Landsat_sinu”.
My target locatoin is “Landsat_laea” I tried using the default option in GRASS GUI as follows:
1.) Select coordinate system parameters from a list
2.) Projection code: laea
3.) Datum with associated ellipsoid:
Central parallel: 30
Central Meridian: -96
False easting: 0
False northing: 0
4.) Datum code: nad83
5.) Select from the list of datum transformation: 1 used in whole nad83 region
+proj=laea
+lat_0=30
+lon_0=-96
+x_0=0
+y_0=0
+no_defs
+a=6378137
+rf=298.257222101
+towgs84=0.000,0.000,0.000
to_meter=1
+datum=nad83
Finish.
Is everything ok with this for the below (required) target definition?
PROJ.4 : '+proj=laea +lat_0=30 +lon_0=-96 +x_0=0 +y_0=0 +datum=NAD83
+units=m +no_defs '
Looks like at some point I am making a small mistake. I must get this as the projected coordinates.
north=1064601.38274499
south=830176.771464028
east=-1960125.15283348
west=-2265106.68066176
Any help is appreciated.
Uttam.
On Wed, Oct 14, 2015 at 4:52 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
[Please keep conversations on the list]
On 14/10/15 23:19, Uttam Kumar wrote:
_
_
This information is for the original data (Source):PROJ.4 : '+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181
+b=6371007.181 +units=m +no_defs ’Coordinate System is:
PROJCS[“Sinusoidal”,
GEOGCS[“GCS_Unknown”,
DATUM[“Unknown”,
SPHEROID[“S_Unknown”,6371007.181,0.0]],
PRIMEM[“Greenwich”,0.0],
UNIT[“Degree”,0.0174532925199433]],
PROJECTION[“Sinusoidal”],
PARAMETER[“False_Easting”,0.0],
PARAMETER[“False_Northing”,0.0],
PARAMETER[“longitude_of_center”,0.0],
UNIT[“Meter”,1]]
Origin = (-10801805.197699999436736,4130102.079069999977946)
Pixel Size = (30.000000000000000,-30.000000000000000)
This information is for the destination data (Target):*
+units=m +no_defs ’In your first mail you said:
Lambert Azimuthal Equal Area, Datum: WGS84
but here the datum is NAD83.
Using your projection info, I get almost exactly the same results in GRASS as you report from ENVI:
On 08/10/15 21:36, Uttam Kumar wrote:> Reprojected in ENVI (Lambert Azimuthal Equal Area, Datum: WGS84)
Corner Coordinates:
Upper Left (-2265106.681W, 1064601.383N)
Lower Left (-2265106.681W, 830181.383N)
Upper Right (-1960126.681W, 1064601.383N)
Lower Right (-1960126.681W, 830181.383N)GRASS 7.0.1 (test_LAEA):~ > v.info -g Image_Boundary_box
west=-2265106.68066176Don’t have the time now to explore the exact differences, but either it’s a question of definition of the bounding box, or it possibly be a question of which specific NAD83 transformation parameters were used.
Moritz
