I am using d.vect.chart to plot some values. My problem is that some of
the higher values are masking out the lower values. Is it possible to
sort the dataset on the fly so that the highest values get plotted first
and get "underneath" the lower values? (My data are stored as a vector
layer, but that is imported from a dbf, so if it is possible to plot it
on the fly from the dbf-file, that is also a solution)
oh, btw, I'm using 6.2.1 on cygwin / XP
Morten
Attached is the source code of a revised version of d.vect.chart which allows this [1].
I have never committed this, as noone seemed interested, but I can. Currently it sorts automatically if you use sizecol, but as recent discussions have shown[2], this should be optional.
[1] http://grass.itc.it/pipermail/grass5/2006-October/026503.html
[2] http://grass.itc.it/pipermail/grass5/2007-April/030523.html ff.
Moritz
(attachments)
d.vect.chart2.tgz (6.35 KB)
