I'm running grass-8.x on a laptop with a 14" screen. Starting grass within a
virtual terminal opens a GUI window that exceeds the monitor's width and
height. Is there a place where I can define the window's geometry globally?
I don't see a config file, such as ~/.grassrc.
TIA,
Rich
On Fri, 28 Apr 2023, Micha Silver wrote:
On my system it's ~/.grass8/wx.json, a json formatted config file.
Micha,
Same here. I didn't use more characers, only .grass.
I think you should try to resize with the "handles" on the window corners. Then using the menu "Settings->Preferences" check the option "Save current
window layout as default", and click "Save". That should keep the window
size for next time.
Will do. Thanks again,
Rich
