[GRASS-user] Specifying color table in v.colors for use with d.vect
   The v.colors manual page lists 'wave' as a color type, but using it in my
d.vect command fails. The two commands and results:
v.colors map=sites layer=1 color=wave use=attr column=howmany rgb_col=bin_col
Converting color rules into categories...
  100%
Writing color rules...
  100%
Color table for vector map <sites@mercury> set to 'wave'
d.vect map=sites display=shape type=point col=wave fill_col=wave rgb_col=bin_col icon=basic/octagon size=7
ERROR: Unknown color: 'wave'
   The map 'sites' is connected to the database table 'stations' via
v.db.connect. The stations table has a column 'bin_col' with the color triplet
associated with a value in the column 'howmany':
  howmany | bin_col ---------+------------
       25 | 70:240:100
       58 | 185:15:155
        1 | 255:85:85
        4 | 232:108:62
       40 | 46:124:216
   I would like guidance on how to use the v.colors module so the colors
specified in the map's attribute table are accepted and used by d.vect.
TIA,
Rich
   Wrong module applied to this need. I found d.vect.thematic and it works
right out of the box.
Rich
