When using v.out.vtk to export a vector map with boundary GRASS breaks and writes out the segments in file. Is there a way to control the nominal size of the segments when exporting it to VTK format. For example, I want to be able to specify it to creates segments that are 1m in legth, or 5m. In other words some way to control the resolution (number of points) to define the lines/boundary in a vector. Is there any other export routine I can use to achieve that?
Would appreciate any tips.
Jitu
On Tue, Oct 7, 2014 at 4:32 PM, Jitendra Kumar <jitendra.ncsu@gmail.com> wrote:
achieve that?
(untested)
Perhaps you split them prior to export?
http://grass.osgeo.org/grass70/manuals/v.split.html
If they are too short, then
http://grass.osgeo.org/grass70/manuals/v.build.polylines.html
Thanks. I was able to use v.to.points with ‘dmax’ option for my purpose.
Jitu
achieve that?
(untested)
