Hi all!
compilation error in ubuntu12.10 x64
GRASS 7.0.svn (nc_spm_08):/usr/local/grass-addons/grass7/imagery/i.spec.unmix > sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn
gcc -g -O2 -I/usr/local/grass-7.0.svn/include -I/usr/local/grass-7.0.svn/include -D_FILE_OFFSET_BITS=64 -DPACKAGE="“grassmods”" -I/usr/local/grass-7.0.svn/include -I/usr/local/grass-7.0.svn/include -o OBJ.x86_64-unknown-linux-gnu/la_extra.o -c la_extra.c
In file included from /usr/local/grass-7.0.svn/include/grass/la.h:34:0,
from la_extra.c:12:
/usr/include/g2c.h:21:1: error: unknown type name ‘__g77_integer’
/usr/include/g2c.h:22:1: error: unknown type name ‘__g77_uinteger’
/usr/include/g2c.h:29:1: error: unknown type name ‘__g77_integer’
/usr/include/g2c.h:33:1: error: unknown type name ‘__g77_longint’
/usr/include/g2c.h:34:1: error: unknown type name ‘__g77_ulongint’
/usr/include/g2c.h:55:1: error: unknown type name ‘__g77_integer’
/usr/include/g2c.h:56:1: error: unknown type name ‘__g77_integer’
/usr/include/g2c.h:57:1: error: unknown type name ‘__g77_integer’
la_extra.c: In function ‘G_matvect_get_column2’:
la_extra.c:22:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:27:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:32:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c: In function ‘mv_mlt’:
la_extra.c:257:9: warning: assignment from incompatible pointer type [enabled by default]
la_extra.c: In function ‘G_vector_product’:
la_extra.c:396:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:401:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:406:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:411:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:417:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:423:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c: In function ‘G_matrix_read2’:
la_extra.c:470:2: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:480:6: warning: format not a string literal and no format arguments [-Wformat-security]
la_extra.c:486:3: warning: format not a string literal and no format arguments [-Wformat-security]
make: *** [OBJ.x86_64-unknown-linux-gnu/la_extra.o] Error 1
Hi all!
from la_extra.c:12:
there was recently some question about spectral unmixing here in the list.
If you didn't modify the source code of the unmixing model to fit Grass 7 it won't work. Spectral unmixing was written by Markus as part of his diploma thesis, is now some years old and is based on Grass 5.something, if I'm not wrong.
Would be great if you can get it to work in Grass 7.x! Seems to me there is quite some interest in this module.
\T
On 08.12.2012, at 05:04, 王德辉 <dehuiw@gig.ac.cn> wrote:
Hi all!
gcc -g -O2 -I/usr/local/grass-7.0.svn/include -I/usr/local/grass-7.0.svn/include -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/usr/local/grass-7.0.svn/include -I/usr/local/grass-7.0.svn/include -o OBJ.x86_64-unknown-linux-gnu/la_extra.o -c la_extra.c
from la_extra.c:12:
On Sat, Dec 8, 2012 at 12:33 PM, Thomas Becker <thomasgeo@gmx.de> wrote:
If you didn’t modify the source code of the unmixing model to fit Grass 7 it won’t work. Spectral unmixing was written by Markus as part of his diploma thesis, is now some years old and is based on Grass 5.something, if I’m not wrong.
Hi all!
from la_extra.c:12:
Hi all!
from la_extra.c:12:
Hi all!
from la_extra.c:12:
