Hi list,
for a validation exercise I need to extract the class values around certain pixel location.
I have a map with all the locations (numbered) and a map with the validation map.
The code you find below is the one I came up with to get this information (only output to terminal for the moment).
However, this code includes a loop and is terribly slow. Has anyone an idea how to speed things up?
Kind regards,
Koen
---------- my code -------------
#!/bin/bash
Get context around pixels…
!!! Bash script only works within the GRASS terminal !!!
get number of pixels in location file… write to variable $pixels…
pixels=r.info -r map=$1 | tail -n +2 | sed 's/max=//'
echo “their are $pixels groundtruth points…”
for i in seq 1 $pixels
do
echo “evaluating pixel $i of $pixels pixels…”
Make MASK based upon pixel number evaluate one at a time. Mask name is MASK and patch.mask
after renaming… If kept as MASK it will apply to all operations and is a system wide setting (not wanted)…
r.mask -o input=$1 maskcats=$i --quiet
g.rename rast=MASK,pixel.mask --overwrite --quiet
create buffer around pixel value…
r.buffer input=pixel.mask output=tmp.buffer distances=4 units=meters --overwrite --quiet
writes temporary reclass rules file…
echo “1 = NULL” > tmp.rules
echo “2 = 1” >> tmp.rules
echo “end” >> tmp.rules
reclass context values using rules above…
r.reclass input=tmp.buffer output=context.mask rules=tmp.rules --overwrite
calculate category statistics for pixel and context location…
r.mapcalculator amap=pixel.mask bmap=$2 formula=AB outfile=pixel.category help=- --overwrite --quiet
echo “pixel data…”
r.stats -c -n input=pixel.category fs=space nv= nsteps=255
r.mapcalculator amap=context.mask bmap=$2 formula=AB outfile=context.category help=- --overwrite --quiet
echo “context data…”
r.stats -c -n input=context.category fs=space nv= nsteps=255
done
clean up tmp files…
rm tmp.rules
g.remove rast=pixel.mask
g.remove rast=context.mask
echo “!!!DONE!!!”
echo “#########################################################################”
