Hello,
I have a raster with different categories (adjacent patches) but when I
buffer this raster file I get a buffer for the whole area and not for each
single patch.
I thought of a loop ( r.mapcalc "select patch cat x" - r.buffer x -
r.mapcalc " set buffer of patch x to null()" ) and then r.patch.
I already did some experiences with
COUNTER = 1
# while [ $COUNTER -lt $max ]; do
while [ $COUNTER < $max ]; do
echo The counter is $COUNTER
r.mapcalc "t1 = if(rast_in == $COUNTER,1,null())"
r.buffer input=t1 output=b.$COUNTER distance=500
let COUNTER=COUNTER+1
done
but failed because COUNTER was not recognized and I don't know at all, if
these bash statements work at all using GRASS.
I welcome any other idea.
Martin
done
Shouldn't your bash variables be quoted within the loop?
while [ "$COUNTER" -lt "$MAX" ] ; do
Similarly for the let statement:
let "COUNTER=COUNTER+1"
~ Eric.
> done
thanks - I added it but the first part:
COUNTER = 1
already caused
COUNTER: command not found
can this bash scripting be used in GRASS like that at all?
Martin
COUNTER = 1
already caused
Martin
Try getting rid of the extra spaces around the assignment statement:
COUNTER=1
~ Eric.
Where was COUNTER not recognized? In the r.mapcalc program or in the while loop?
In bash, for you to define a variable you can't put spaces between the
variable and the equal sign
try COUNTER=1 and NOT COUNTER = 1
On Jan 10, 2008 5:12 PM, Martin Wegmann
> > done
COUNTER = 1
already caused
Martin
grass-user mailing list
grass-user@lists.osgeo.org
>COUNTER = 1
>already caused
>Martin
COUNTER=1
thanks everybody - now it's working:
#!/bin/bash
echo -n "input:"
read input
r.to.vect $input output=tttemp feature=area --o
v.to.rast tttemp output=tttemp_in use=cat --o
g.remove vect=tttemp
max=`r.info -r "tttemp_in" | grep max | cut -f2 -d=`
COUNTER=`r.info -r "tttemp_in" | grep min | cut -f2 -d=`
while [ "$COUNTER" -le "$max" ];
do
echo counter ist "$COUNTER"
r.mapcalc "tttemp_1 = if(tttemp_in == "$COUNTER",1,null())"
r.mapcalc "tttemp_inv = if(isnull(tttemp_1),1,null())" >/dev/null 2>&1
r.buffer input=tttemp_inv output=tttemp_buffer distances=100 --o
r.mapcalc "tttemp_area."$COUNTER" =if(isnull(tttemp_buffer),1,null())"
done
var1=1
var2=0
# until [ "$var1" -eq "$max" ]
while [ "$var1" -le $max ]
do
echo "$var1" plus "$var2"
r.mapcalc "tttemp_area.0 = tttemp_area.1"
r.patch input=tttemp_area.$var1,p.$var2 output=p."$var1" --o
var1=$(( $var1 + 1 ))
var2=$(( $var2 + 1 ))
done
