Is it possible to split a polygon in equal areas smaller polygons?
Thanks
This is a very old problem.
IMO, there is no simple solution, becouse the computer cannot guess the shapes and the orientation of the polygons you want.
I’ve worked with land partitioning with CAD and the solution was to use LISP program that guess many split positions until it gets equal areas.
First you split in two polygons, than in four and so on.
A possible aproach in GRASS is to use a grid with “v.mkgrid”.
Other aproache is to have a “model poligon” with the shape and area that you want and use this polygon like a stamp.
I still curious about other solutions, and if someone knows anything else please share.
Regards.
Pablo Torres Carreira
Date: Thu, 23 Sep 2010 09:35:39 -0400
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] split polygon
Thanks
_______________________________________________ grass-user mailing list grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
