I’ve been looking for ways of grass gis splitting a polygon into multiplepolygons with a line shapefile and wondering are there tools in Grass to do this!!
Thanks
Le gach dea ghui,
Shane Carey
GIS and Data Solutions Consultant
Thanks
Le gach dea ghui,
Shane Carey
Hola, no si buscas algo parecido a esto que es en QGIS
dejo el link de acceso al video:
https://www.filemail.com/d/bspgwgmhyxruqcu?&showconfirmation=true
Saludos
Eddison
El dom., 10 mar. 2019 a las 8:39, Shane Carey (<careyshan@gmail.com>) escribió:
Thanks
Le gach dea ghui,
Shane Carey
grass-user mailing list
grass-user@lists.osgeo.org
On Sun, Mar 10, 2019 at 3:39 PM Shane Carey <careyshan@gmail.com> wrote:
I've been looking for ways of grass gis splitting a polygon into multiplepolygons with a line shapefile and wondering are there tools in Grass to do this!!
Please take a look at
https://grass.osgeo.org/grass76/manuals/v.edit.html
Thanks Markus, it doesnt seem to do the trick for me unfortunately.
Thanks for your help
Le gach dea ghui,
Shane Carey
On 10/03/19 15:39, Shane Carey wrote:
Does the following correspond to what you are looking for ?
test = polygons
test2 = lines
# patch lines and polygons together
v.patch test,test2 out=test_patched
# transform lines to boundaries
v.type test_patched out=test_patched_bound
# break boundaries at intersections
v.clean test_patched_bound tool=break out=test_patched_bound_clean
# add centroids to new areas
v.centroids test_patched_bound_clean out=final
This can be easily scripted into a small addon module.
Moritz
Hey Moritz,
Thanks for coming back to me. I figured it out with the following script
import processing
polys = QgsVectorLayer(r"C:\Users\shane.carey\Desktop\poly.shp", ‘poly’, ‘ogr’)
lines = QgsVectorLayer(r"C:\Users\shane.carey\Desktop\s1line.shp", ‘lines’, ‘ogr’)
output = r"C:\Users\shane.carey\Desktop\split2.shp"
processing.run(“saga:polygonlineintersection”,{ ‘POLYGONS’:polys, ‘LINES’:lines,‘INTERSECT’:output})
Le gach dea ghui,
Shane Carey
