Message: 6
Date: Sun, 7 Mar 2010 06:02:51 -0800 (PST)
Subject: [GRASS-user] SQL and GRASS
To: grass-user@lists.osgeo.org
Message-ID: <1267970571671-4690410.post@n2.nabble.com>
Content-Type: text/plain; charset=us-ascii
GRASS is connected to a MySQL data base
I want to select polygons which are not 0
so do I do:
d.vect SiteGrid3 where "SquareNumber<>0 "
or
v.db.select map=SiteGrid3 column=square_no where=<>0
I have a second non spatial table described below(right)
grass SiteGrid3 (one) Pottery table (many)
|cat|SquareNumber| |SquareNumber|Type|
|1 |1 | |1 |mug |
|2 |2 | |1 |mug |
|3 |3 | |1 |mug |
it continues...
so now I want to select the square number but be able to use v.what to
return the amount of pottery.
Any ideas? This is easy in sql but I want to show it in GRASS
Thanks
Gary
Gary,
Easy.
d.vect SiteGrid3 where="SquareNumber<>0"
or
v.db.select map=SiteGrid3 column=square_no where="square_no<>0"
In Grass-GIS, "where" statements are generally followed by the equals sign, then the statement.
Richard C
Hi Richard,
Thankyou for your help, I have been using:
or
however as you see in my example in my initial post I have a second table:
|cat|SquareNumber| |SquareNumber|Type|count|
|1 |1 | |1 |mug |12
|2 |2 | |1 |mug |14
|3 |3 | |1 |mug |3
it continues...
d.vect SiteGrid3 where "SquareNumber<>0 " is great for table1 (left) but I
want to query a non spatial table, the pottery table. So I want to display
all squares where Pottery.Type ='mug'
and also:
display: select SiteGrid3.SquareNumber, Pottery.SUM(count) from SiteGrid3,
Pottery
I may need an inner join so like this
from SiteGrid3, Pottery
Inner JOIN SiteGrid3
ON Pottery.SquareNumber=siteGrid3.SquareNumber
where (possible where statement)
so displaying data based on a complex sql statement
I hope this clarifies my problem
Thanks again
Gary
View this message in context: http://n2.nabble.com/SQL-and-GRASS-tp4690410p4714753.html
