On 4/12/19 19:58, Markus Neteler wrote:
Thanks for your answers.
In fact I need it in Python...
Using SQL, you can do something like this (SQLite version):
create table mytab (cat int, label varchar, labelint int);
inserts...
select * from mytab;
1|forest|
2|forest|
3|forest|
4|street|
5|street|
6|forest|
7|forest|
8|street|
9|grass|
10|grass|
SELECT cat, label, rank() OVER win FROM mytab WINDOW win as (ORDER BY label);
1|forest|1
2|forest|1
3|forest|1
6|forest|1
7|forest|1
9|grass|6
10|grass|6
4|street|8
5|street|8
8|street|8
Playing around with that should allow you to feed your table.
Or in pure python:
- get unique labels with v.db.select col=label group=label and put them in a list
- get numbers with something like this: classnums = [x+1 for x in range(len(labels))]
- zip the two lists: zip(labels, classnums)
- for each tuple in the list:
v.db.update col=labelint value=tuple[1] where=label=tuple[0]
Probably there are more elegant solutions.
Moritz
Micha Silver <tsvibar@gmail.com <mailto:tsvibar@gmail.com>> schrieb am Mi., 4. Dez. 2019, 18:57:
How about doing this in R? The labels will be read into R as
factors, and the factor levels can easily be extracted as numbers.
Something like this:
micha@tp480:~$ v.info <http://v.info> -c stations
Displaying column types/names for database connection of layer <1>:
INTEGER|cat
INTEGER|station_num
TEXT|station_he
TEXT|station_en
TEXT|type
INTEGER|x_coord
INTEGER|y_coord
DOUBLE PRECISION|long
DOUBLE PRECISION|lat
INTEGER|elev
TEXT|date_open
DOUBLE PRECISION|dist
DOUBLE PRECISION|azim
micha@tp480:~$ R
R version 3.5.2 (2018-12-20) -- "Eggshell Igloo"
Copyright (C) 2018 The R Foundation for Statistical Computing
Platform: x86_64-pc-linux-gnu (64-bit)
> library(rgrass7)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: GRASS 7.6.0 (2019)
and location: ITM
> use_sf()
> stations = readVECT("stations")
WARNING: Vector map <stations> is 3D. Use format specific layer creation
options (parameter 'lco') to export <in 3D rather than 2D
(default).
Exporting 94 features...
100%
> stations['new_station_num'] = as.numeric(stations$station_en)
> stations$new_station_num
[1] 71 26 6 55 54 63 7 8 31 30 46 84 92 38 32 88 27 12 67 62 47
33 53 76 89
[26] 2 86 11 40 65 64 45 13 85 60 59 1 74 73 22 19 15 39 50 56 14
44 23 36 83
[51] 41 42 43 18 17 75 16 82 81 37 48 28 87 3 66 10 34 91 61 93 94
72 5 4 68
[76] 78 77 9 29 51 58 57 49 52 24 25 80 79 35 70 69 90 21 20
> writeVECT(SDF=stations, vname="new_stations")
Best regards, Micha
On 04/12/2019 19:11, Markus Neteler wrote:
I have a landuse map with text labels (forest, street, ...). For
r.learn.ml <http://r.learn.ml> I need to have them as numeric classes.
It is not important for me which number is assigned but I search for
an automated solution, i.e. SQL statement unless there is a different
way.
So:
cat|label|label_int
1|forest|1
2|forest|1
3|street|2
4|forest|1
5|street|2
6|urban|3
I guess I have done that already some years ago but I can't remember
the trick
thanks for a hint,
grass-user mailing list
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
-- Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
https://orcid.org/0000-0002-1128-1325
