[GRASS-user] SQL in GRASS
Hello list,
I tried the following expression in a Python script, but it does not work (I need to subtract the lowest value for column „srtmh“ from all other values for that item and write the result to column „strmh2“):
grass.run_command(‘v.db.update’, map=‘dgnpt’, column=‘srtmh2’, qcolumn=“(‘srtmh’ - (select min(‘srtmh’) from ‘dgnpt’))”)
The SQL expression itself seems to be ok, because it works in SpatiaLite in the following form:
update dgnpt set srtmh2 = srtmh-(select min(srtmh) from srtmp);
What could be the reason that it does not work in GRASS/in the script?
And by the way, when I try scripts I often get a message „Process ended with non-zero return code 1. See errors in the (error) output.“
But what is that error output? Where can I read the error message in detail? Sorry for that question, but I found no hints in the manual pages. :frowning:
Thanks a lot for help, Uwe
On 2/06/20 14:42, Uwe Fischer wrote:
Hello list,
Please be more specific than just saying "it does not work". Do you see an error message ? Wrong results in the table ?
grass.run_command('v.db.update', map='dgnpt', column='srtmh2', qcolumn="('srtmh' - (select min('srtmh') from 'dgnpt'))")
I think your quoting is off.
For me such a command works. E.g. in the NC demo dataset:
g.copy vect=censusblk_swwake,test
v.db.addcolumn test col="test double precision"
and then in python:
import grass.script as g
g.run_command('v.db.update', map='test', column='test', value="'HH_SIZE'-(SELECT avg('HH_SIZE') FROM test)")
g.run_command('v.db.update', map='test', column='test', value="HH_SIZE-(SELECT avg(HH_SIZE) FROM test)")
However, if I quote like you do:
g.run_command('v.db.update', map='test', column='test', value="'HH_SIZE'-(SELECT avg('HH_SIZE') FROM 'test')")
the result is all zeroes.
This tells the database that all words in single quotes are strings, not db entity names.
Try running
update dgnpt set srtmh2 = 'srtmh'-(select min('srtmh') from 'srtmp')
You probably won't get what you expect, either.
Generally, you have to look further up for the actual error, at the beginning of the error message. E.g. when I run the above command but using an incorrect table name:
g.run_command('v.db.update', map='test', column='test', value="HH_SIZE-(SELECT avg(HH_SIZE) FROM test2)")
I get:
DBMI-SQLite erreur de pilote :
Error in sqlite3_prepare():
no such table: test2
ERREUR : Error while executing: 'UPDATE test SET test=HH_SIZE-(SELECT
          avg(HH_SIZE) FROM test2)'
   File "/usr/lib/grass78/scripts/v.db.update", line 129, in <module>
     sys.exit(main())
   File "/usr/lib/grass78/scripts/v.db.update", line 120, in main
     grass.write_command('db.execute', input='-', database=database, driver=driver, stdin=cmd)
   File "/usr/lib/grass78/etc/python/grass/script/core.py", line 588, in write_command
     return handle_errors(returncode, returncode, args, kwargs)
   File "/usr/lib/grass78/etc/python/grass/script/core.py", line 342, in handle_errors
     raise CalledModuleError(module=None, code=code,
grass.exceptions.CalledModuleError: Module run None db.execute input=- database=/home/mlennert/GRASSDATA/nc_spm_08_grass7/user1/sqlite/sqlite.db driver=sqlite ended with error
I see the 'Process ended with non-zero return code 1" and going further up I see:
and even further up:
Moritz
Glad to hear that. Please keep threads in the mailing list.
Moritz
Am 2. Juni 2020 18:59:15 MESZ schrieb Uwe Fischer <gisfisch@t-online.de>:
Hello Moritz,
thanks again, it works now. Indeed I had to many useless quotes. Maybe
it came from former attempts I did with db.execute statements, where I
needed a lot of quotes. But I could have seen it myself, comparing with
the SpatiaLite statement that worked fine.
Thanks you.
Mit freundlichen Grüßen,
UWE FISCHER
Ingenieurbüro Fischer
Esbecker Str. 8
31036 Eime
Tel.: 05182/8325
Mobil: 0172/8876934
Von: grass-user [mailto:grass-user-bounces@lists.osgeo.org] Im Auftrag
von Moritz Lennert
Gesendet: Dienstag, 2. Juni 2020 15:07
An: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] SQL in GRASS
Hello list,
work
other
and then in python:
SpatiaLite
Try running
output.“
pages. :frowning:
I get:
    sys.exit(main())
write_command
handle_errors
output.
up I see:
Moritz
grass-user mailing list
