Hi!
I have tried to read the documentation and the mailing list for how to
connect to a SQLite database. So far I have done this:
1. db.connect driver=sqlite database='/home/espen/db.sqlite'
2. Created a new vector map called test
3. v.db.connect map=test table=GSHHS_f_L2 -o key=PK_UID
However I get this warning:
WARNING: SQLite driver: unable to parse decltype: POLYGON
WARNING: SQLite driver: column 'Geometry', SQLite type 2 is not supported
The table <GSHHS_f_L2> is now part of vector map <test> and may be deleted
or overwritten by GRASS modules
And running v.info map=test show that the layer does not have any objects
| Layer: test |
| Mapset: PERMANENT |
| Database: /home/espen/Dokumenter/grassdata |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: espen |
| Organization: |
| Source date: Wed Jun 23 08:55:30 2010 |
| Type of Map: vector (level: 2) |
| Number of points: 0 Number of areas: 0 |
| Number of lines: 0 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: Lat/Lon |
| N: 0 S: 0 |
| E: 0 W: 0 |
| Digitization threshold: 0 |
| Comments: |
Could anybody explain to me what the warning means, and why I cannot
access the features? The only thing i can guess is that I can only use
version 1 of SQLite? However, I am not familiar with the different
versions of SQLite.
Kind regards,
Espen Isaksen
Hi Espen,
the regular SQLite tables driver does not support
geometry storage in SQLite databases.
If you want to connect to a spatially enabled
SQlite3 database, use v.in.ogr instead.
Ben
----- Original Message -----
Hi!
supported
supported The table <GSHHS_f_L2> is now part of vector map <test> and
may be deleted
objects
| Layer: test |
| Mapset: PERMANENT |
| Title: |
| Map scale: 1:1 |
| Organization: |
| Map is 3D: No |
| N: 0 S: 0 |
| E: 0 W: 0 |
| Comments: |
versions of SQLite.
Kind regards,
Espen Isaksen
_______________________________________________ grass-user mailing
list grass-user@lists.osgeo.org
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
Thanks Achim and Ben for your quick answers! I never even thought
about that(a bit embarrassing really
I suppose that means I am back to the horribly slow import through
v.in.ogr. Practically impossible for me to import a 100 mb shapefile.
If anybody has suggestions for good performance, please go ahead and
tell me.
Espen
2010/6/24 Achim Kisseler <achim.kisseler@jupiter.uni-freiburg.de>:
This is because SQLite is not SpatiaLite (SQLite with spatial extension).
GRASS does not support SpatiaLite as far as I know.
If you just want to use the Data from Spatiallite, you can export the tables
as shape-files or csv and import these to GRASS.
Hope it helps a bit,
Achim
Espen Isaksen schrieb:
Hi!
| Layer: test
| Mapset: PERMANENT
| Title:
| Map scale: 1:1
| Map format: native
| Organization:
| Map is 3D: No
| Projection: Lat/Lon
| N: 0 S: 0
| E: 0 W: 0
| Comments:
versions of SQLite.
Kind regards,
Espen Isaksen
grass-user mailing list
You could try compiling GDAL with GRASS support and
using ogr2ogr directly to convert from the external
format to GRASS.
Ben
tell me.
Espen
> extension).
> the tables
> Achim
>> Hi!
>> to
>> supported
>> and may be deleted
>> objects
>> | Layer: test
>> | Mapset: PERMANENT
>> | Location: newLocation
>> | Title:
>> | Map scale: 1:1
>> | Map format: native
>> | Organization:
>> | Map is 3D: No
>> | Projection: Lat/Lon
>> | N: 0 S: 0
>> | E: 0 W: 0
>> | Comments:
>> cannot access the features? The only thing i can guess is that I
>> can only use
>> versions of SQLite.
>> Kind regards,
>> Espen Isaksen
My understading from this page is that it is not possible to compile
OGR with Grass write support?
http://gdal.org/ogr/ogr_formats.html
Am I wrong? This might indicate that write support is possible:
http://grass.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
Espen
2010/6/24 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>:
format to GRASS.
Ben
tell me.
Espen
> extension).
> the tables
> Achim
>> Hi!
>> to
>> supported
>> and may be deleted
>> objects
>> | Layer: test
>> | Mapset: PERMANENT
>> | Title:
>> | Map scale: 1:1
>> | Map format: native
>> | Organization:
>> | Map is 3D: No
>> | Projection: Lat/Lon
>> | N: 0 S: 0
>> | E: 0 W: 0
>> | Comments:
>> can only use
>> versions of SQLite.
>> Kind regards,
>> Espen Isaksen
On Thu, Jun 24, 2010 at 10:35 AM, Espen Isaksen <espen.isaksen@gmail.com> wrote:
tell me.
You could try grass 7, see [1]
Really big shapefiles like GADM v1 (gadm1.shp is 913 MB) will take at
least 1 hour, though.
Alternatively, get v.in.gshhs from grass-addons [2], get the original
GSHHS data [3] and import those with v.in.gshhs
Markus M
[1] http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#Radim.27s_TODO_list
[2] http://grass.osgeo.org/wiki/GRASS_AddOns#v.in.gshhs
[3] ftp://ftp.soest.hawaii.edu/pwessel/gshhs/gshhs_2.0.tbz
Achim
Hi!
| Layer: test
| Mapset: PERMANENT
| Title:
| Map scale: 1:1
| Map format: native
| Organization:
| Map is 3D: No
| Projection: Lat/Lon
| N: 0 S: 0
| E: 0 W: 0
| Comments:
versions of SQLite.
Kind regards,
Espen Isaksen
Ok, so that means that grass 7 should be better at importing ogr
vector formats then right? My 100 mb file has now been running for
more than 24 hours and not done yet.
My GSHHS data was really just a test, I need to import other large
shapefiles as well. But thanks for the tip
Espen
2010/6/24 Markus Metz <markus.metz.giswork@googlemail.com>:
tell me.
Markus M
Achim
Hi!
| Layer: test
| Mapset: PERMANENT
| Title:
| Map scale: 1:1
| Map format: native
| Organization:
| Map is 3D: No
| Projection: Lat/Lon
| N: 0 S: 0
| E: 0 W: 0
| Comments:
versions of SQLite.
Kind regards,
Espen Isaksen
No, unfortunately you are right.
This is not an option for you.
There is some severe inefficiency in
the way v.in.ogr handles attribute and
geometry data during import, which makes
the whole process slow.
Unfortunately, no one has yet stepped forward
to re-design the logics (as far as I am
aware).
Ben
Espen
> format to GRASS.
> Ben
>> tell me.
>> Espen
>> > extension).
>> > the tables
>> > Achim
>> >> Hi!
>> >> to
>> >> supported
>> >> and may be deleted
>> >> objects
>> >> | Layer: test
>> >> | Mapset: PERMANENT
>> >> | Title:
>> >> | Map scale: 1:1
>> >> | Map format: native
>> >> | Organization:
>> >> | Map is 3D: No
>> >> | Projection: Lat/Lon
>> >> | N: 0 S: 0
>> >> | E: 0 W: 0
>> >> | Comments:
>> >> can only use
>> >> versions of SQLite.
>> >> Kind regards,
>> >> Espen Isaksen
