[GRASS-user] sqlite-db broken?
Hi again,
I did another test now and found out following:
It seems that the problem with the sqlite database
might be related to the directory of my grass location.
When I try my to save the location on my local drive
everything works, there is just a problem when
my location points to a directory which is actually a mounted
samba network drive (mount cifs).
Here an output of the directory which is actually a network drive:
radinger@grassgis:~$ ls -la /home/radinger/U_Radinger/05_GRASS/GRASS_locations/
total 0
drwxrwxrwx 5 radinger radinger 0 Jul 16 12:01 .
drwxrwxrwx 6 radinger radinger 0 Jul 13 14:09 ..
drwxrwxrwx 4 radinger radinger 0 Jul 16 11:43 xxx
drwxrwxrwx 4 radinger radinger 0 Jan 26 2009 gisdemo_ncspm
drwxrwxrwx 4 radinger radinger 0 Jul 12 14:16 spearfish60
drwxrwxrwx 3 radinger radinger 0 Jul 16 10:44 xxx
and:
radinger@grassgis:~$ ls -la /home/radinger/U_Radinger/05_GRASS/GRASS_locations/gisdemo_ncspm/sqlite/
total 6
drwxrwxrwx 3 radinger radinger 0 Jul 16 13:15 .
drwxrwxrwx 4 radinger radinger 0 Jan 26 2009 ..
-rwxrwxrwx 1 radinger radinger 24 Jul 16 12:08 .bash_history
-rwxrwxrwx 1 radinger radinger 556 Jul 16 12:03 .bashrc
-rwxrwxrwx 0 radinger radinger 512 Jul 16 12:04 cifs2e55
-rwxrwxrwx 1 radinger radinger 0 Jul 16 12:03 sqlite.db
drwxrwxrwx 2 radinger radinger 0 Jul 16 12:02 .tmp
-rwxrwxrwx 1 radinger radinger 74 Nov 3 2008 VAR
drwxrwxrwx 1 radinger radinger 0 Nov 3 2008 vector
-rwxrwxrwx 1 radinger radinger 361 Nov 3 2008 WIND
Does anyone know hat causes the problem exactly and what should I change?
The db-connection is set to $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db (checked in the VAR file as well)
Maybe the GRASS can't tranlate from the relative path to a hardcoded one when the $GISDBASE is already located on a mounted network drive?
/Johannes
-------- Original-Nachricht --------
Datum: Mon, 16 Jul 2012 12:04:40 +0200
Von: "Johannes Radinger" <JRadinger@gmx.at>
An: grass-user@lists.osgeo.org
Betreff: [GRASS-user] sqlite-db broken?
I used to use db.test (with test=test1) to test my sqlite database
connection. In the most recent verson of GRASS 6.4.3 (rev 52380) it seems to be
broken. I tried it on some of my own databases and a freshly downloaded
sample dataset (small NC dataset, mapset=sqlite). I started it from the gui but
it just get stucked in the process (no output after several
minutes)...stopping it leaves the database in an incosistent state.
Thats why I tried just to simply copy a vector file (e.g streams) from
PERMANENT to sqlite. Then I get the error message: Unable to open header file
of vector <streams@sqlite> Unable to read head file....
Somehow working with sqlite doesn't work properly on my machine (Ubuntu
12.04) although I the command sqlite3 in the terminal works....
I also tried it with 6.5 SVN (rev. 52380) and a fresh NC dataset again:
db.test just gives: Busy SQLITE db, already waiting for 10 seconds...
What else do I need to test so that someone of you might know the problem
of my basic database functions (creating tables eg. when tranforming from
raster to vector etc.)? Can anyone reproduce this or is it just a behavior
due to my own compilation (configured with sqlite3 support)?
/Johannes
grass-user mailing list
after some search in the internet, it seems
the sqlite doesn't work very well with samba-network
drives (mounted via cifs). There is somehow
an issue with the locking of the db.
Does anyone have experience with using GRASS/SQLITE
on a cifs-mounted GRASS location?
What I found is following mount-option:
nobrl
Do not send byte range lock requests to the server. This is necessary for certain applications that break with cifs style mandatory byte range locks (and most cifs servers do not yet support requesting advisory byte range locks).
But I am not really sure if this will work or even destroy something.
So I'll let that judge some expert of you!
cheers,
Johannes
Datum: Mon, 16 Jul 2012 14:14:48 +0200
An: "Johannes Radinger" <JRadinger@gmx.at>, grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] sqlite-db broken?
Hi again,
total 0
and:
total 6
/Johannes
> Hi,
seems to be
gui but
file
problem
from
behavior
> /Johannes
On Mon, Jul 16, 2012 at 2:14 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
Hi again,
total 0
and:
total 6
This file:
looks strange to me.
There is a relatively new feature in sqlite3, it want to obtain an
exclusive lock on the directory where the sqlite database is. If any
file in that directory is kept open by another application, sqlite
will refuse to open the database. Maybe the above mentioned file
cifs2e55 is kept open by the cifs driver.
Some things to try:
set default db connection to
$GISDBASE/$LOCATION_NAME/$MAPSET/db/sqlite.db
manually create the directory
and copy the vector again.
Try GRASS 7 because the sqlite driver in GRASS 7 prints many more
errors reported by sqlite3.
Try to open the sqlite database directly with sqlite3 or one of the sqlite GUIs.
Use nfs instead of cifs if possible.
HTH,
Markus M
/Johannes
/Johannes
On Mon, Jul 16, 2012 at 4:02 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
I think I found the reason [0]:
"When SQLite creates a journal file on Unix, it opens the directory
that contains that file and calls fsync() on the directory, in an
effort to push the directory information to disk."
If another process is modifying files or just keeping files open in
this directory while sqlite calls fsync(), opening the sqlite database
will fail.
Markus M
[0] http://www.sqlite.org/lockingv3.html
nobrl
cheers,
Johannes
Hi again,
total 0
and:
total 6
/Johannes
> Hi,
seems to be
gui but
file
problem
from
behavior
> /Johannes
I've become quite a fan of sshfs as a single-user replacement for
nfs, but there are a number of other FUSE methods to try too.
Hamish
wrote:
> Hi,
will fail.
Markus M
sounds like the reason for that problem. Unfortunately I have to mount my windows-samba network drive with cifs... Anyway I just made a workaround now using a working copy of my GRASS locations on my local drive and backing that up onto my cifs-mounted network drive.
I'll try it also with GRASS 7 and see what I get as output...
Anyway thank you for your help!
/johannes
> nobrl
locks).
> cheers,
> Johannes
>> Hi again,
>> total 0
>> and:
>> total 6
change?
one
>> /Johannes
>> > Hi,
>> seems to be
downloaded
the
>> gui but
from
header
>> file
(Ubuntu
again:
>> problem
>> from
>> behavior
>> > /Johannes
>> > _______________________________________________
